Topic: Small RGB LED Matrix? (Read 5118 times) previous topic - next topic
zooto68
So far I have only ever seen 6cm x 6cm RGB LED Matrix and nothing smaller. Do they come in smaller sizes?
zooto68
SteelToad
zooto68
No I mean an 8x8 RGB Matrix.
SteelToad
Ohhhh, you meant a rgb matrix, like it says in the title I did a poor job of reading  ::)
How small are you hoping to go ?
halley
The design intent of these parts is to go into high-visibility high-power long range displays.  From casino machines to Times Square newstickers to Jumbotrons.  Bigger is better, because people won't be standing within arm's reach of them.  The 60mm size just ended up being something of an industry standard.
Any smaller parts are going to be for "arm's reach" applications, and they will go with a much more efficient scheme to display much higher resolution:  LCD, OLED, etc.
westfw
Heh.  Who has a library to turn a typical AM LCD panel into something that looks like an RGB LED array ?
(that would actually be pretty neat, and possibly within the realm of something actually doable on an Arduino, since you could configure the amount of storage actually used to match the app...  Where's that Sparkfun display...)
Grumpy_Mike
I think you are more in the realms of RGB OLED displays here. It depends on how many you were planing to stack together. But small displays like 100 by 100 might suit what you are trying to do.
zooto68
Yeah but OLED's aren't as much fun as an LED array. ;)
SteelToad
Quote
Yeah, but you cant 'touch' an LED array to change its output ... well, not more than once  8-)
zooto68
Sure you can. LED's can be used as feedback devices too :)
BetaDelta
That is true.
And half the fun is interfacing all those LEDs to make an Image, not just running an LCD screen!
/me
"C++ : Where friends have access to your private members." - Gavin Russell Baker
zooto68
Exactly!! It's more of a challenge. :)
BetaDelta
Making your own RGB LED matrix would be a good challenge!
/me
