Topic: Fan control help needed (Read 1 time) previous topic - next topic
Tisa
Hi guys, I'm posting for the first time but I have been reading the forums alot and have learned alot aswell. But now I've come to an impass and I need some help.
My problem is that I'm trying to control a computer fan(Arctic Cooling F8 PWM) with the PWM pin from an Arduino Due but nothing happens. I'm sure I've gotten the connections and the code right since it works on a different fan.
The fan itself turns on when connected to a 12V battery, but analogWrite() does nothing. Now I've done some research but I'm not really sure what I'm looking at. There's alot of mention of PWM frequency which I don't fully understand. I read that most of the CPU fans work on a 25kHz frequency but I'm not sure what this has to do with my Due.
Basicly what I need is that I need to understand how all this works, any explanations and documentation are greatly appreciated.
bullroarer
What code are you trying to run on the Due?
Tisa
Code: [Select]
int LDR = A0;
int LDRValue = 0;
int light_sensitivity = 750;
    pinMode(13, OUTPUT);
    LDRValue = analogRead(LDR);
    Serial.println(LDRValue);
    delay(50);
    if (LDRValue < light_sensitivity)
         analogWrite(13, 100);
          analogWrite(13, 200);
This is the code I got running. Basicly it's hooked up to a lightresistor so when the lights dim, the fan turns on. Like I mentioned earlier it works on another CPU fan I got, the problem might be the PWM frequency.
alnath
how is all this wired ?
could you post a schematic ?
monkeyhacker
IIRC 3 pin fans cannot be controlled with PWM through the fan itself.
If it's a four pin fan then you need a common ground between the Arduino and the fan.
If it's a 3 pin fan you can still control it via PWM, but you will need to add a transistor to switch it via PWM.
Tisa
#6
Apr 24, 2014, 09:14 am Last Edit: Apr 24, 2014, 08:50 pm by Tisa Reason: 1
Sorry, I forgot to add the common ground. It is a 4 pin fan. I'll try the transistor and see if it helps.
Tisa
Sorry for the late reply, I added a TIP120 transistor and some diodes and got it to work. Thank you very much for the tip!
