Topic: The 1284P, a sleeping beauty on a $9 UNO size board? (Read 14625 times) previous topic - next topic
retrolefty
#15
May 07, 2014, 02:49 am Last Edit: May 07, 2014, 02:55 am by retrolefty Reason: 1
Can't imagine why there would be a perception issue.
I'm guessing that it just an i/o board - If it is and anti-Arduino thing,
you don' have to use Arduino on it.
Could be good for offloading  real-time i/o.
I'm pretty interested in the board.
I'm curious what goes the 28/30 pin dip spot.
I'll send him an email.
One bummer that I just noticed on the Sleeping Beauty BB is that
I can't use the ISP port with my existing 6 pin cable.
If you have keyed idx connectors, they don't fit because the ISP pins
are too close to the 1284 and the connector key prevents the cable
from being plugged in.
--- bill
I had the same problem with trying to fit the six pin IDC connector from my USBasp programmer onto the bobrino board, just too close to the 1284P DIP socket. However just a little filling on the side on the connector made it a nice snug fit, and there seemed to be plenty enough meat on the connector end not to affect the integrity of the connector.
bperrybap
In terms of cores. The sleeping beauty files have issues.
There are some things that are just plain broken in the sleeping beauty variant file.
I guess I'll move it into Jacks latest 1284 core and then fix it and then do a pull request.
(I'm off to talk to folks in the other thread about accepting SB support in the 1284 core).
--- bill
bperrybap
I've corrected the issues in the SB variant file and now have my openGLCD library
up and running on the Sleeping Beauty BB board using the latest mighty 1284 core
that is currently being updated to latest 1.0.5 core.
--- bill
wanderson
#18
May 10, 2014, 02:46 pm Last Edit: May 10, 2014, 03:04 pm by wanderson Reason: 1
I ordered two SB's with the chip, and received them; however, I also received two empty PCB's labeled PI-DUINO-BB that are clearly not the same layout as the SB.  I have searched the web, and the OP's website and can find no indication of what these additional boards are.  Any one have any ideas?
EDIT: Never mind, I see the earlier post where this is board for the Pi, and the designer isn't planning on supporting it...
mrburnette
And that is a mistake based upon an email exchange with Wayne... he does intend on supporting this board and I regret that I misread/misinterpreted his email which indicated he had changed his mind on some aspects, just not production and selling of same.
Regards,
Ray
firebirduino
The extra PCB is for the Teensy3 with RPI interface.  The reason that I gave it out as a freebie is that if you even are not interested in the Teensy3, you may be able to use it next month as a fixture for a small application that I hope you may be interested.  I should include a note, sorry for wasting your time. I will learn from this.
I will support the Pi-Duino-BB.  Gerber files will be posted once it's finalized.  Everyone can make it, but I am not interested in making it.  I was thinking to sell it for $9 to help some users get up and running faster, but later changed my mind and would prefer to give it away for free, because I don't have enough free time in the near future.
The schematic and docs will be posted next week.  I have a project deadline on June 14, sorry that I couldn't do it sooner.
Back to the SB-BB, Gerber files will be posted once it's finalized.  I won't trade mark the SB,  anyone can use it and make boards.  If you want to sell boards please state clearly that they are not made by Firebirduino.
I discovered that many users on this forum still prefer through hole products, I will remove the FT231XS and replace it with a 6-pin FTDI connector on the next revision.
I will remove the 328P out of the SB, the 328P is not needed on a 1284P board  if there is a demand for the 1284P.   I feel there is a demand for the 1284P, thanks for the core refresh by Jack and others.
The original pin file developed by Roger Schaefer may have issues, but I ran some programs including DFrobot LCD and it was fine.  Apparently it did not pass a more advanced test, like Bill's graphic LCD libraries.
Bill, thanks for the corrections.
Wayne
OldMicroGuy
mrburnette
Applying copper hobby tape to restrict crystal movement.
CrossRoads
mrburnette
No tape needed on Bobuino/1284 boards ...
It's a coffee spewer response 4sure!  I do love my Bobuinos.   XD
Like, I could take the silly 3-pin socket off but it is actually not a bad idea for the one board I am using on the project bench... I'm thinking about popping in a 20MHz for play...
Maybe I need to buy one of your screw-down shields to use with the crystal connection ... just to be sure all is tight!  :smiley-eek-blue:
Ray
OldMicroGuy
The crystal is socketed so the user can easily experiment with different speeds, if they wish.  I believe that Wayne is now using a socket with a tighter fit.
Roger
wanderson
The two I received late last week have machine pin sockets and the crystal seems quite secure.  If it turns into a problem, removing a three pin socket isn't too tough.
mrburnette
Roger
Yes, like I said originally: "It is a two-edged sword."  Some will think it a blessing, some a curse.  For the bench, a socket is no big deal.  For projects, it could be.  Another issue would be serial resistance and the added inductance, although at 16MHz, this is likely no big deal.
My preference would be to have the SB done like the Bobduino... a high-quality 16.000MHz crystal soldered.  Hackers would have no issue with desoldering and replacing the crystal.  The "screw-down" was a me-to-Crossroads joke.
Ray
CrossRoads
Too subtle for me - I have a revised original Bobuino design that I'm about to send off for boards, and it has screw terminals like a mega screw shield, but I hadn't posted any pics yet - glad you explained!
mantoui
I just ordered a sleeping beauty.  What are the specs on the 16 MHz crystal? (part number?  datasheet?)
