We have a BINGO.
If 10 is selected all readings are 100.
I raised the sample numbers from 5 to 100.
All OK.
Then I lowered to 90 but then I get readings radom ranging from 89 to 91.
So no need to go higher but low is not prefered. :-)
Paco
You need to be a lot more precise.
Do you mean that you changed the maxTests value from 5 to 100 and it still worked?
By "alll readings" do you mean with and without the scale.read() command?
What did you lower to 90?
I wonder if you mean that you lowered intervalMillis to 9 (not 90)?
In what circumstances did you get 89 and when did you get 91?
Did you get it to print scaleData so you could see if it is giving correct values? (I have no way to test that).
Do you know what to do next or do you need some more advice?
...R
