Topic: Bike interface OBD (Read 146462 times) previous topic - next topic
o5i_
Apr 27, 2014, 12:20 am Last Edit: Apr 28, 2014, 11:16 pm by o5i_ Reason: 1
Hi
I hava a suzuki gsx-r 1000 and want to log the serial data that the bike transmits over the k-line diagnostics interface called SDS:..
First step ist to attach a pc and log the comunication between pc and ecu. I want to use an arduino board if it ist possible...
Is it possible to connect each serial line to an rx line of the arduino and log them to sd?
I dont know exactly the baud rates, this is what i neet to find out...
Later i want to use the logged information to create a file definition and write direktly to ecu and store the recieved data to sd and maybee monitor it to an tft or webserver...
There are people who did this, i have a lot of definitions from them, but im not sure about the comunication...
robtillaart
please replace the BMP image with a JPEG as it now take almost 3MB for a relative simple image.
a jpeg for this would be (estimate)  30x smaller.
you need a logic analyzer to determine the baudrate and to see the data.
another point of attention is what voltage comes out of the ECU as Arduino and the (USB) PC uses 0..5V levels.
The ECU might use real rs232 which uses higher voltages.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
o5i_
Ok..
About the Voltage, i need to add some ics, because the data is transfered by K-Line.. It is not problematic...
But i dont know if the sketch work.
I put a serial read of both serials in loop an than a print command... Is the arduino fast enough to write every single bit or i need to write first into ram? I think it sounds a litlebit strange, but im new here :D
Later i post the sketch i have made...
robtillaart
probably the speed of the OBD is low to medium speed to be 100% reliable. You could use MAX speed for your print command
What board are you using UNO/MEGA?
Rob Tillaart
o5i_
Ok it works, i used the 10400 baud as described for kwp2000 on the RX Serial Ports.
First i connect to the print port whit 9600 and of course it was to slow, i changed it to 57600 and it was ok :D
Now i have send and response data...
Here my sketch
Code: [Select]
  // initialize serial ports:
  //console
  Serial.begin(57600);
  // Serial PORT 1
  Serial1.begin(10400);
  // Serial PORT 2
  Serial2.begin(10400);
  // Welcome Message
  Serial.println("##################################################");
  Serial.println("###########  Serial Logging Interface  ###########");
    if (Serial1.available()) {
      Serial.print("ECU: ");
      Serial.print(Serial1.read(), HEX);
      Serial.println("");
    if (Serial2.available()) {
      Serial.print("PC: ");
      Serial.print(Serial2.read(), HEX);
      Serial.println("");
But now i neet to know how the initialiton works... I saw something in the obduino sketch an i think i try that...
o5i_
#5
Apr 28, 2014, 10:53 pm Last Edit: Apr 28, 2014, 11:01 pm by o5i_ Reason: 1
This is the Logfile:
I think the pc writes a lot of strings whitout reading answeres at the same time.  The Ecu at this point is much slower answering because the string is longer...
Ex.
PC     Startpoint: bla bla bla bla bla bla
ECU   Startpoint: blablablablabla blablablablabla blablablablabla blablablablabla blablablablabla blablablablabla
Code: [Select]
PC: 80
ECU: 12
PC: 12
ECU: F1
PC: F1
ECU: 2
PC: 2
ECU: 21
PC: 21
PC: 80
ECU: 80
PC: 26
ECU: 26
ECU: 80
ECU: F1
ECU: 12
ECU: 66
ECU: 61
ECU: 80
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 57
ECU: 6B
ECU: 62
ECU: FF
ECU: FF
ECU: FF
ECU: 80
ECU: 15
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 80
ECU: 0
ECU: FF
ECU: 80
ECU: 0
ECU: FF
ECU: FF
ECU: FF
ECU: 80
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 80
ECU: 80
ECU: 80
ECU: 80
ECU: 0
ECU: D
ECU: 0
ECU: D
ECU: 0
ECU: D
ECU: 0
ECU: D
ECU: FF
ECU: FF
ECU: 80
ECU: 0
ECU: 15
ECU: 0
ECU: 1D
ECU: 0
ECU: 17
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 80
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 80
ECU: 80
ECU: 80
ECU: 80
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 8C
ECU: 80
ECU: F0
ECU: C1
ECU: FF
ECU: FF
ECU: FF
ECU: FF
PC: 80
ECU: FF
PC: 12
ECU: FF
PC: F1
ECU: 16
PC: 2
ECU: E5
PC: 21
ECU: 5
PC: 8
ECU: 0
PC: AE
ECU: 0
ECU: FF
ECU: FF
ECU: 14
ECU: 80
ECU: 12
ECU: F1
ECU: 2
ECU: 21
ECU: 8
ECU: AE
ECU: 80
PC: 80
ECU: 12
PC: 12
ECU: F1
PC: F1
ECU: 2
PC: 2
ECU: 21
PC: 21
PC: 8
ECU: 8
ECU: AE
PC: AE
ECU: 80
ECU: F1
ECU: 12
ECU: 34
ECU: 61
ECU: 8
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 3A
ECU: A1
ECU: 52
ECU: 4E
ECU: A1
ECU: 0
ECU: FF
ECU: 0
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: FF
ECU: FF
ECU: 40
ECU: 40
ECU: 40
ECU: 40
ECU: FF
ECU: F4
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 4
ECU: 8
ECU: FF
ECU: FF
ECU: 2B
ECU: 80
PC: 80
ECU: 12
PC: 12
ECU: F1
PC: F1
ECU: 2
PC: 2
ECU: 21
PC: 21
ECU: 8
PC: 8
ECU: AE
PC: AE
ECU: 80
ECU: F1
ECU: 12
ECU: 34
ECU: 61
ECU: 8
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 3A
ECU: A1
ECU: 52
ECU: 4E
ECU: A1
ECU: 0
ECU: FF
ECU: 0
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: FF
ECU: FF
ECU: 40
ECU: 40
ECU: 40
ECU: 40
ECU: FF
ECU: F4
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 4
ECU: 8
ECU: FF
ECU: FF
ECU: 2B
ECU: 80
PC: 80
ECU: 12
PC: 12
ECU: F1
PC: F1
ECU: 2
PC: 2
ECU: 21
PC: 21
ECU: 8
PC: 8
ECU: AE
PC: AE
ECU: 80
ECU: F1
ECU: 12
ECU: 34
ECU: 61
ECU: 8
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 3A
ECU: A1
ECU: 52
ECU: 4E
ECU: A1
ECU: 0
ECU: FF
ECU: 0
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: FF
ECU: FF
ECU: 40
ECU: 40
ECU: 40
ECU: 40
ECU: FF
ECU: F4
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 4
ECU: 8
ECU: FF
ECU: FF
ECU: 2B
ECU: 80
PC: 80
ECU: 12
PC: 12
ECU: F1
PC: F1
ECU: 2
PC: 2
ECU: 21
PC: 21
ECU: 8
PC: 8
ECU: AE
PC: AE
ECU: 80
ECU: F1
ECU: 12
ECU: 34
ECU: 61
ECU: 8
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 3A
ECU: A1
ECU: 52
ECU: 4E
ECU: A1
ECU: 0
ECU: FF
ECU: 0
ECU: FF
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: 0
ECU: FF
ECU: FF
ECU: 40
ECU: 40
ECU: 40
ECU: 40
ECU: FF
ECU: F4
ECU: FF
ECU: FF
ECU: FF
ECU: 0
ECU: 0
ECU: 4
ECU: 8
ECU: FF
ECU: FF
ECU: 2B
ECU: 80
robtillaart
small remark
Code: [Select]
      Serial.println("");
Code: [Select]
      Serial.println(Serial1.read(), HEX);
Rob Tillaart
o5i_
robtillaart
try to change loop to
Code: [Select]
        Serial.print("PC:\t");
        while(Serial2.available())
            int b = Serial2.read();
            if (b < 10) : Serial.print("0");
            Serial.print(b , HEX);
            Serial.print(" ");
        Serial.print("ECU:\t");
        while(Serial1.available())
            int b = Serial1.read();
            Serial.print(" ");
might give you more insight in the handshakes
Rob Tillaart
o5i_
Now i need to do this whit the arduino, dont know where begin, maybee by decoding it?
I have a question, the digital outputs, if state is not defined are they on high resistance? There are some pins on the ecu e want to switch but i only know that they can be switched by switches, if i put them from 0-5V maybee it want work.. 2 are switched to 0V one to 5V... Is it possibe to use the arduino as serial to usb converter? If i put a switch the inputs from usb / serial 0 to an other port... Or is it dangerous for the arduino because it is the programing interface?
o5i_
Hi, i did some work...
But i added only some analog inputs and one serial for the Wideband Lambda...
How is the best way to get the code? I think an array would be the best way to go?
How can i create the checksum of an array whit 61 values?
Code: [Select]
#include <SD.h>
#include <UTFT.h>
#define CONSOLE Serial                      // CONSOLE PORT
#define CONSOLEBAUD 57600
#define WBL Serial1                          // WIDEBAND LAMBDA PORT
#define WBLBAUD 9600
#define SDS Serial2                          // SDSPORT
#define SDSBAUD 10400
const int chipSelect = 53;                  // SD CS Pin
const int startlog = 8;                     // Start stop
const int mode = 9;                         // Logger - Flash mode
float sensors[99];
String name_sensors[99];
int inputpin;
int numbersensors;
int lineposition;
int sensornumber;
int SDPRESENT;
int SDDETECT;
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
UTFT myGLCD(SSD1289,38,39,40,41);
void getvalues();
void clear_console();
void sd_print();
void console_print();
void tft_printvalues();
void sd_init();
  CONSOLE.begin(CONSOLEBAUD);
  WBL.begin(WBLBAUD);
  SDS.begin(SDSBAUD);
  pinMode(startlog, INPUT);
  pinMode(mode, INPUT);
  pinMode(10, OUTPUT);
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(SmallFont);
  myGLCD.fillScr(0, 0, 150);
  myGLCD.setBackColor(0, 0, 150);
  myGLCD.setColor(255,255,255);
  getvalues();
  sd_init();
  sd_print();
  console_print();
  tft_printvalues();
  clear_console();
void getvalues () {
  sensornumber = 0;
  inputpin = 3;
  name_sensors[sensornumber] = "Abgas Temp (analog) [C]";
  sensors[sensornumber] = float(analogRead(inputpin)) / 1.5 - 200;
  sensornumber = 1;
  inputpin = 4;
  name_sensors[sensornumber] = "Motor Temp (analog) [C]";
  sensors[sensornumber] = float(analogRead(inputpin)) * 0.1;
  sensornumber = 2;
  inputpin = 5;
  name_sensors[sensornumber] = "Drosselklappe (analog) [%]";
  sensors[sensornumber] = float(analogRead(inputpin)) * 0.103 ;
  sensornumber = 3;
  name_sensors[sensornumber] = "Gemisch (seriell) [LAMBDA]";
  if (WBL.available() > 0) {
    sensors[sensornumber] = WBL.read();
  numbersensors = sensornumber;
void tft_printvalues() {
  for (sensornumber = 0;sensornumber <= numbersensors; sensornumber = sensornumber + 1) {
    myGLCD.print(name_sensors[sensornumber], LEFT, lineposition);
    myGLCD.print(String(int(sensors[sensornumber])), RIGHT, lineposition);
    lineposition = lineposition + 20;
  lineposition = 0;
void console_print() {
    CONSOLE.print(name_sensors[sensornumber]);
    CONSOLE.print(": ");
    CONSOLE.println(sensors[sensornumber]);
void clear_console() {
  CONSOLE.write(27);
  CONSOLE.print("[2J");
  CONSOLE.write(27);
  CONSOLE.print("[H");
void sd_init() {
  while (!SDDETECT) {
    CONSOLE.println("###### Detecting SD Card ######");
    myGLCD.print("###### Detecting SD Card ######", CENTER, 220);
    if (!SD.begin(chipSelect)) {
      CONSOLE.print("#### SD Card not found ######");
      myGLCD.print("###### SD Card not found ######", CENTER, 220);
      SDDETECT++;
    else {
      CONSOLE.print("###### SD Card Initialized ######");
      myGLCD.print("###### SD Card Initialized ######", CENTER, 220);
      SDDETECT++;
      SDPRESENT++;
void sd_print() {
  if ((SDPRESENT)&&(SDDETECT)) {
    File datafile = SD.open("LOGFILE.TXT", FILE_WRITE);
    if (datafile) {
      CONSOLE.println("###### Writing into LOGFILE.TXT ######");
      myGLCD.print("###### Writing into LOGFILE.TXT ######", CENTER, 220);
      datafile.print(millis());
        datafile.print(":");
        datafile.print(sensors[sensornumber]);
      datafile.println(":");
      datafile.close();
    else {
      CONSOLE.println("###### SD Card writing ERROR ######");
      myGLCD.print("###### SD Card writing ERROR ######", CENTER, 220);
      SDPRESENT = 0;
robtillaart
Quote
a for loop over all 61 values
- either with a defined formula
- or your own formula  (simplest is to add all the values and see if the sum matches)
Rob Tillaart
o5i_
Ok, i have managed the formula.. Now, at the start of the communication i need to do a fastinit how it ist described in kwp protocol.. I need to put the Serial output for 300ms high than 25ms low and again 25ms low before i can start the serial communication whit 10400baud... or slowinit is 0x33 @ 5 baud...
Can i do "serial.begin(baud)" more than 1 time?
robtillaart
Yes you can but this sounds more like you need a dedicated handshake , setting high and low "manually".
in my (limited) experience the very low baud rates are not that reliable
Rob Tillaart
o5i_
How can i manage it?
I want to do fastinit how described in kwp2000 ISO 14230 ...
here are a lot of snippets i have found in posts
http://fish.x64.me/doc/infos.txt
