Topic: 3 buttons for 3 LEDS - SOLVED (Read 2099 times) previous topic - next topic
yoavac
Apr 27, 2014, 06:28 pm Last Edit: May 04, 2014, 05:22 pm by yoavac Reason: 1
Hi All,
I am writing a simple program that is supposed to have 3 buttons control 3 LEDS when the button is double clicked.
The code itself works fine for a single button + LED and for 2 buttons + 2 LEDS. When I put the 3rd one in it won't work.
I believe it has something to do with the UNO HW restricting me but I could not find anything online to suggest so.
If I switch the button pins (use 2,3,4 or 4,5,6 etc) I can only get 2 LEDS to work. I can swap the cable from the pin to the button (swap between 2 and 4 for example assuming 2 works and 4 doesn't)  - now the circuit that was connected to 4 (and didn't work)  is connected to 2 and works (and vise versa) suggesting it is not my wiring or circuit.
I am using pins (2,3,4) for button and (7,8,9) for LED but used all sorts of comps.
When I use this setup Pin 4 doesn't work.
Code below
Thanks!
Code: [Select]
//button declerations
const int buttonGRN = 2;
const int buttonRED = 3;
const int buttonGRN1 =4;
// led decleratons
int lightOutputGRN = 7;
int lightOutputRED = 8;
int lightOutputGRN1 = 9;
int bounceTime = 50;
int doubleTime = 500;
int lastReadingGRN = LOW;
int lastReadingRED = LOW;
int lastReadingGRN1 = LOW;
long onTimeGRN = 0;
long onTimeRED= 0;
long onTimeGRN1= 0;
long lastSwitchTime = 0;
long lastSwitchTimeRED = 0;
long lastSwitchTimeGRN1 = 0;
 pinMode(buttonGRN, INPUT);
 pinMode(lightOutputGRN, OUTPUT);
 pinMode(buttonRED, INPUT);
 pinMode(lightOutputRED, OUTPUT);
 pinMode(buttonGRN1, INPUT);
 pinMode(lightOutputGRN1, OUTPUT);
 Serial.begin(9600); // to communicate with serial
         int readingGRN1 = digitalRead(buttonGRN1);
 //first pressed
 if (readingGRN1 == HIGH && lastReadingGRN1 == LOW)
   onTimeGRN1 = millis();
//released
 if (readingGRN1 == LOW && lastReadingGRN1 == HIGH)
   if (((millis() - onTimeGRN1) > bounceTime))
    onReleaseGRN1();
 lastReadingGRN1 = readingGRN1;
 int readingGRN = digitalRead(buttonGRN);
//first pressed
 if (readingGRN == HIGH && lastReadingGRN == LOW)
   onTimeGRN = millis();
//released
 if (readingGRN == LOW && lastReadingGRN == HIGH)
   if (((millis() - onTimeGRN) > bounceTime))
     onReleaseGRN();
 lastReadingGRN = readingGRN;
 int readingRED = digitalRead(buttonRED);
//first pressed
 if (readingRED == HIGH && lastReadingRED == LOW)
   onTimeRED = millis();
//released
 if (readingRED == LOW && lastReadingRED == HIGH)
   if (((millis() - onTimeRED) > bounceTime))
    onReleaseRED();
 lastReadingRED = readingRED;
} //end loop
void onReleaseGRN()
 if ((millis() - lastSwitchTime) >= doubleTime)
   lastSwitchTime = millis();
   return;
 if ((millis() - lastSwitchTime) < doubleTime)
         //light up led for 3 sec then turn off
        digitalWrite(lightOutputGRN, HIGH);
        delay(3000);
        digitalWrite(lightOutputGRN, LOW);
void onReleaseRED()
 if ((millis() - lastSwitchTimeRED) >= doubleTime)
   lastSwitchTimeRED = millis();
   return;
 if ((millis() - lastSwitchTimeRED) < doubleTime)
        digitalWrite(lightOutputRED, HIGH);
        delay(3000);
        digitalWrite(lightOutputRED, LOW);
void onReleaseGRN1()
 if ((millis() - lastSwitchTimeGRN1) >= doubleTime)
   lastSwitchTimeGRN1 = millis();
   return;
 if ((millis() - lastSwitchTimeGRN1) < doubleTime)
        digitalWrite(lightOutputGRN1, HIGH);
        delay(3000);
        digitalWrite(lightOutputGRN1, LOW);
[EDIT]
I forgot to mention I also did the following test:
I added one line of code (see below for exact location in code)
       Serial.println(lastReadingGRN);
and did he same for GRN1 (the problematic LED)
When I do that for GRN - the serial monitor shows a lot of 0-s, then I click (once) and it changes to 1-s and then 0-s again after I release.
when I do this for GRN1 - serial shows 0-s, then I click once and is shows 1-s, but does not show 0-s again when I release.
Any ideas as to why it doesn't set the value back to LOW?
Code: [Select]
//released
     onReleaseGRN();
Thanks!
[/EDIT]
PaulRB
Hi yoavac,
Can I just check: you do have pulldown resistors on your switch inputs? What you describe sounds like they may be "floating".
Paul
yoavac
Hi Paul,
yes, i do have a pulldown resistor on each one of my inputs
Thanks
3dprinter
There is nothing in you code that is "Limited by the UNO hardware".
From bitter experience I know that cut-n-pasted code-snippets and then changing variable names (your identical code sections that use ...RED, GRN and ...GRN1) is prone to forgetting or mixing up a name. I've looked and didnt find one, but these are hard to see.
PaulRB has asked about the pulldown resistor - this assumes the switch pulls the line high.
There is the possibililty that pin4 is "bad". If you played a lot with your UNO you may have "stressed" the pin. Try using pin 5 instead of 4.
yoavac
I actually tried changing the pins several time, but i figured heck, i'll give it another try.
5 didn't work either :(
but i moved things around and managed find enough that do work.
sometimes you just have to try one more time haha.
Thanks a lot of the help!!! :smiley-mr-green:
3dprinter
Well, if it works then everybody is happy. :)
If it works and you do not know why it suddenly worked, then you may suddenly have a surprise. (It stops working)
Some possible faults have been mentioned. In addition I can suggest you may not have the wiring you think you have - which is why the troubles started with the 3rd LED/button. You may have an errenous wiring one that is wrong but happens to work for the wrong reasons.
