Topic: [ Urgent ] TESTING THE ARDUINO UNO BOARD (Read 1 time) previous topic - next topic
CHAOS-THEORY
Hey guys,
i need a quick answer; am sending my friend to get me the Arduino Uno board and as you may know i want to check it's full ability.
So is there a way to test the board there before buying it?
CrossRoads
Quote
How would we know that?
Have you seen the Atmega328P datasheet?
http://www.atmel.com/devices/ATMEGA328P.aspx
660 pages long describing all the capabilities it has. Would take a while and require several different pieces of test hardware to check it all out: SPI interface, I2C interface, analog inputs, PWM outputs, digital IO, interrupts, and so on.
Write yourself a couple of test sketches:
Make sure you can interact with the serial monitor at different speeds.
Make sure you can blink an LED on each pin, will give you some confidence all the output drivers are working.
Make sure you can read a high & low on each pin, will will give you some confidence all the input pins are working.
Make sure you can read all the analog pins as you vary a  pot from 0 to 5V, will will give you some confidence all the analog pins and analog mux and ADC are working.
Make sure you can both INTs and PCINTs on all pins.
Make sure you can interface with an I2C device.
Make sure you can interface with an SPI device.
etc.
That should keep you busy for a while to start.
CHAOS-THEORY
well, euh dude; thanks for your precise answer.
but i have sent a noobish human being to get me the board; so i don't think theres nothing i can do myself.
so i ll just hope it's intact cause it's a brand new one, but you don't know these days; too much of a confidence, is less of a negligence.
i'll reply when i get it, thanks brother !
dannable
The most basic test that I can think of which proves that the board is operational is to load the blink sketch, change the on / off ratio to some thing like 100/1900 and upload it to the board.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
CHAOS-THEORY
yeah, i ve been thinkin about that thanks
