Thank you @roadfun, we'll try to check free space before running it
Regarding performance, we observed similar performances. However, when running on the SD card the Yun could go much much faster
When configuring the SD card, we forced writes to be in sync
This ensures that files do not corrupt even if you suddenly unplug the yun while you're writing a file (or at least this reduces the changes that such a corruption may happen)
However, if you just run the following command
mount -o remount,async /dev/sda2
you'll see a great performance improvement (this is temporary: once you'll reboot, it will get back to "sync")
This is much more unsecure as files may get corrupted or you may lose data if the yun loses power while writing on the SD card
It's a trade-off and we chose with the conservative way as it is more secure and gives you a similar experience
roadfun:
My first Yun conversion went smoothly. But my second one failed (error detailed below). I surmised this was a issues with free space on / (of course that's why I was happy to see this extension scheme). I recalled I was at about 90% before running the conversion script. I removed a couple of packages to get to 83% full on / and re-ran the sketch. It ran correctly.
Bottom line is you may want to ensure you have about 80% free space on / before running this conversion.
Software list updated. Installing software (this will take a while)...
err. installing e2fsprogs mkdosfs fdisk
@roadfun: Good point! thank you!!
I've checked and the 4 software you need to install for this procedure requires around 700KB.
So, I've added a function that checks if you have at least 1MB of free space on the flash memory and stops the procedure if you don't have enough space.
NewLine:
This is a really good idea!
However I would rather just run/tweak the Linux script instead of via the sketch. Any Chance of publishing this? If not, I'll extract it from the sketch myself.
We decided to adopt the "Arduino sketch way" to keep the procedure as simple as possible (means you don't have to deal with the Linux terminal).
I'm sorry but we are not going to publish a Linux bash script with the same commands. However, extracting them form the sketch is very simple.
the procedure has been easy, thanks but during this I haven't read carefully and I made the Linux partition bigger than I wanted and trying to do the procedure again "arduino" says that the sd is already been prepared/modified..how can I do?
Wow this is awesome, thanks for making the process easy and repeatable. Looking forward to installing a lot more packages with the room available.
Dumb question, but has anyone tried installing and using GCC on the yun and an expanded filesystem? I'm guessing the limited memory and CPU will make compiling anything serious impossible, but it should be possible to do simple stuff right?
Suppose I have 2 Yuns. On Yun1 I do the above and actually move the OS to the SD card.
Yun2 still uses the flash. How difficult would it be to modify Yun2 so that is works from the SD card from Yun1?
I am thinking of using the SD card as a way of distributing the whole setup of a Yun to people that do not want to configure the Yun themselves. It would be great if they could buy a Yun, plugin the SD-card and done.
tdicola:
Seconded on the request for someone to figure this out...
Unix without a native C compiler is pretty limited. The suggestion to cross compile is valid if you're rebuilding the OS, but is very problematic for "normal" people. It only works on one or two specific versions of Linux - No Mac compiling, and definitely no Windows support. The process of building the cross compiler is torturous to say the least. Everyone reports problems.
If there was an easily available, and simple to use cross compiler that shipped with the Arduino IDE then that would be a good start, but currently cross compiling "helloWorld" from scratch is days of work, and would require setting up a VM just of that purpose.
The suggestion that it's impractical to compile natively is bogus. Especially with this upgrade in place, storage is no longer an issue, and 400MHz/64Mb is actually pretty decent (I've compiled GCC on a 16MHz Machine with 4Mb RAM - it took pretty much a whole day, but that was totally OK).
The Linux side of the Yun is currently underused, because there's no easy way to write C programs for it...
This isn't meant to sound ungrateful - I appreciate the progress being made on the Yun. I'm just hoping to get this onto the todo list, as it would radically change the way we could work with the YUN.
dctsystems:
I would love to see an installable gcc on the yun! It would also be a nice contribution to OpenWrt, that (AFAIK) has never had a installable package for gcc in 10 years
Since you've already done that, you may want to contribute with your experience
I've seen a couple of people say they've had something working, but nothing released. The biggest problem is... there's no simple C compiler for Yun! Need to build the native compiler with a cross compiler, which I need to build on Debian, which is a pain.
It was a torturous process, but I've got a working GCC toolchain running on Yun. It's got a couple of hacks in places and its completely untested, but I've complied a couple of simple test programs with it.
I'm currently making a tar file with a complete toolset in, and I'll add a link to that as soon as its uploaded somewhere. Hopefully my notes can help someone else to a better job, and turn into a proper installable package.
The sketch worked great, but as I noted in a separate thread, for me the 2GB data partition I specified runs around 12 times slower than the ext4 overlay partition. Rebooting without the sd card, inserting and reformatting sda1 as ext4 dropped a 1MB file create from 120 seconds to around 7 seconds.
This sketch will format your micro SD card and use it as additional disk space for your Arduino Yun.
Pleaseyou have ONLY your micro SD card plugged in: no pen drives, hard drives or whatever.
Do you wish to proceed (yes/no)? yes
Starting Bridge...
Ready to install utility software. Please ensure your Arduino Yun is connected to internet.
Ready to proceed (yes/no)? yes
Updating software list...
e2fsprogs mkdosfs fdisk rsync installed
Proceed with partitioning micro SD card (yes/no)? yes
Enter the size of the data partition in MB: 4000
Partitioning (this will take a while)...
mkfs.vfat 3.0.12 (29 Oct 2011)
err. formatting to FAT32
This is the system info :
Firmware Version Linino Barrier Breaker devel / LuCI Trunk (svn-r9877)
Kernel Version 3.8.3
First I try to reinstall the OpenWrt-Yun image by the web panel.
The WLAN keep blinking over 10-15 minutes and don't stop , which I think it is not right.
Then I try to do it using Terminal and I got the following error :
root@MyArduino:~# run-sysupgrade /mnt/sda1/openwrt-ar71xx-generic-yun-16M-squash
fs-sysupgrade.bin
cp: read error: Input/output error
