Topic: What kind of jack (Read 741 times) previous topic - next topic
Jaychad
Im wanting to power my arduino via a battery pack.   what kind of jack should be used, and is there any where on the arduino boards, uno and mega, that i can solder the  wires to instead?
knut_ny
barrel jack  2.1mm inner 5.5 outer.
Power can be supplied to Vin-pin and gnd
If your supply is 5V (4V..5,5V) regulated - go to 5V-rail (bypassing onboard regulator)
Ny
fungus
You can solder wires to the bottom of the board under the power input jack. There's some big solder joints there, perfect for adding a wire.
There's three pads. Check with a multimeter to see which pin is which. Two are connected to GND, one is connected the center pin of the jack.
Advanced Arduino
Jaychad
awesome.  Thank you again
Billysugger
Mate, pop into Maplin, order code HH60Q. ;-)
Jaychad
