Topic: symmetric board edge connector? (Read 646 times) previous topic - next topic
vxir
Hi guys a couple of questions about hw parts that I'll bet you DIY guys may have experience with.
I'm trying to make a small Arduino clone and am looking for the cheapest way to connect two boards edge-to-edge using a symmetric connector.
A simple example would be to use 2 female right angle connectors and then put (floating) extra long male pins between them.  But when I price that out its .50 for each female RA connector and then there are the male pins.
But perhaps you guys know of something even simpler.  Perhaps there is a card-edge solution?
And on another subject, I want to be able to use an ATX (PC) power supply to power a board, but I really don't need THAT much power.  So I settled on the hard-disk connector as the perfect solution.  But everyone just calls it the "molex 4 pin".  I can't figure out what the male side (to mount on the board) is really called so I can buy some!  Anyone every buy some of these?
Thanks!
