Topic: Whats the best low pressure solenoid valve for regulating water flow? [SOLVED] (Read 16179 times) previous topic - next topic
schollz
I have a 5 gallon bucket of water suspended 5 feet in the air and I want to use an arduino to control the water coming out of a hole in the bottom of the bucket (it goes to a drip irrigation system). This is about 2 psi of pressure. I've tried two kinds of solenoid valves attached to the bottom of the barrel with no success. I've tried this one: http://tinyurl.com/okkem3r which I discovered has a pressure rating too high and doesn't work at all. Then I tried this one: http://tinyurl.com/ptmkd8d which is rated for 0 psi but very very little water goes through. What do you suggest?
zoomkat
Quote
Put the valve as low as possible so it has more pressure across it.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
dave-in-nj
cannot use a solenoid 'valve'   you can use a solenoid that is connected to a spring to close the tubing.  then pull the solenoid back to allow the tubing to pass water.
you can use a solenoid connected to a real valve
you can use a peristaltic pump
dave-in-nj
you might be able to use a battery solenoid from a device on the end of a garden hose.
uses less than 10 inhces of water to allow water to pass.  just a trickel.
I have used the clippard minimatic over the years back in the day of pnuematics.  it slided an o-ring past the opening.  allows flow without needing line pressure.   however, they are small.  and not cheap.
you can get a motorized ball valve from amazon for low cost.
retrolefty
There are solenoid valves that work with 0 inlet pressure, they just cost more:
http://www.adafruit.com/product/996
Robin2
Could you have a flap or a plug inside the bucket that is held down by the water pressure. It could be lifted a little using a servo on the rim of the bucket with a string or wire attached to the flap.
Heath Robinson rules (Rube Goldberg for our transatlantic colleagues).
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
dave-in-nj
I stand corrected.
https://www.stcvalve.com/STC-DOWNLOAD/2W160-500.pdf
the call this a direct lift solenoid valve.
PeterH
How about trying an ordinary domestic ball valve operated by a servo? That gives you very accurate and repeatable position control, minimal power consumption when it isn't moving, and doesn't involve any DIY on the 'wet' part of the problem.
Alternatively, do away with the valve completely and just use a micropump to transfer water from the bucket to the top of the drip line.
schollz
allblueskys
I set something up similar and used a 0 pressure gravity valve like this one.
http://www.electricsolenoidvalves.com/1-2-12v-dc-electric-brass-solenoid-valve/
It is a diaphragm type valve so when you energize it the whole valve opens up. That ball valve is a good solution to but they can be kind of pricey.
gevax
http://gevax.com/urun.php?id=453&baslik=referans%201901-KBND010-120-12DC%20kullan%FDm%20alan%FD%20GENEL%20MAKSAT&lang=eng
Pilot Operated Solenoid Valves
Gevax solenoid valves pass through all life-time and
performance tests,and all the valves are %100 applied
functional tests before delivery.
The pressure values are given for AC coils; for DC
applications Pmax may decrease as per applications
features.
DustinMuise
I am working with a rain barrel  (60 gallons, at a height of 3 feet from drip, etc), and trying to run it off an 'orbit irrigation time-controller' (like the kind of computers that automatically water lawns with those pop-up sprinkler systems, etc) ....
I tried using the standard automatic solenoid valve, obviously without success because the water source I am using has very little pressure (1 psi).
I would like to find a valve that I can use with the timer system, so that everything works as it should (and without losing water pressure or velocity from the valve, etc).
All the valve solutions that have been proposed and shared in this forum thus far, seem to run at 12 volts.   // & the timer~wire system runs on 24 volts.    ....    I wanted to ask if this is a problem   ....   could I use a 12 volt solenoid on a 24 volt wire  ?
thanks
dave-in-nj
hijacking a thread is a no-no, hijacking a solved thread is not going to get favourable results.
DustinMuise
sorry, I am new to this forum writing stuff.   // is what you wrote in reply to my earlier post?
// I am unfamiliar with what "hijacking a thread" means   ...
I wrote something about trying to use a 12v solenoid valve in the place of automatic 24v solenoid valve in an orbit irrigation system.  ... /// I am not so savvy with electrical engineering stuff, etc.
