Topic: Filter library test (Read 25056 times) previous topic - next topic
AdaZus
Hello Forum,
I tested the filter from
http://jeroendoggen.github.io/Arduino-signal-filtering-library/ but the result was not as expected.
As sensor I used a microphone with amplifier on Analog In 0 (A0) at my ArduinoUNO:
https://www.sparkfun.com/products/9964 .
Then I created a filter on: http://www.schwietering.com/jayduino/filtuino/ with following input values: Cebyshev; Low pass; 2ndorder; Chebyshev ripple -3; sample rate 1000Hz; Lower Corner 300Hz; prewarp on; Double type
Then I opened "SignalFilter.cpp" and substitute the Chebyshev Filter of 2nd Order with my new Filter code:
Code: [Select]
  if(_order==2) {
_v[0] = _v[1];
_v[1] = _v[2];
_v[2] = (4.153748378268e-1 * data)
+ ( -0.4501779675 * _v[0])
+ ( -0.2113213838 * _v[1]);
return
  (_v[0] + _v[2])
        +2 * _v[1];
To see if my new filter works I plotted out the Serial Port with the "real time plotting tool":
http://forum.arduino.cc/index.php?topic=58911.0
But before I merged and adapted the "Chebyshev" Example from SignalFilter-Library with the plot sketch from the site:
http://www.negtronics.com/simplot/simplot-code-samples/plot-analog-input-data
Here my new Sketch:
Code: [Select]
// Arduino Signal Filtering with RealTimePlot
// Arduino Signal Filtering Library
// Copyright 2012-2013 Jeroen Doggen (jeroendoggen@gmail.com)
//http://jeroendoggen.github.io/Arduino-signal-filtering-library/
//http://www.schwietering.com/jayduino/filtuino/
SimPlot Demo
Samples Analog Input and sends them over serial port to be plotted in SimPlot.
This Demo software uses the default serial port "Serial".
Upto to 4 channels of data can be plotted.
For details of SimPlot go to
#include <SignalFilter.h>
SignalFilter Filter;
  Serial.begin(57600);
  Filter.begin();
  Filter.setFilter('c');
  Filter.setOrder(2);
int buffer[20]; //Buffer needed to store data packet for transmission
int data1;
int data2;
int data3;
int data4;
  //Read Analog channels. You can connect accelerometer, gyro, temperature sensor etc to these channels
  //I delete the second analogRead and substitute them with the filtered signal
  data1 = analogRead(0);
  data2= Filter.run(data1);
  data3 = analogRead(2);
  data4 = analogRead(3);
  //You can plot upto 4 channels of data. Uncomment only one of the options below
   plot(data1,data2,data3,data4);   //Plots 4 channels of data
//  plot(data1,data2,data3);      //Plots 3 channels of data
// plot(data1,data2);            //Plots 2 channels of data
  // plot(data1);                  //Plots 1 channel of data
  delay(10); //Read and plot analog inputs every 10ms.
//Function that takes 4 integer values and generates a packet to be sent to SimPlot.
void plot(int data1, int data2, int data3, int data4)
  int pktSize;
  buffer[0] = 0xCDAB;             //SimPlot packet header. Indicates start of data packet
  buffer[1] = 4*sizeof(int);      //Size of data in bytes. Does not include the header and size fields
  buffer[2] = data1;
  buffer[3] = data2;
  buffer[4] = data3;
  buffer[5] = data4;
  pktSize = 2 + 2 + (4*sizeof(int)); //Header bytes + size field bytes + data
  //IMPORTANT: Change to serial port that is connected to PC
  Serial.write((uint8_t * )buffer, pktSize);
//Function that takes 3 integer values and generates a packet to be sent to SimPlot.
void plot(int data1, int data2, int data3)
  int pktSize;
  buffer[1] = 3*sizeof(int);      //Size of data in bytes. Does not include the header and size fields
  buffer[2] = data1;
  buffer[3] = data2;
  buffer[4] = data3;
  pktSize = 2 + 2 + (3*sizeof(int)); //Header bytes + size field bytes + data
//Function that takes 2 integer values and generates a packet to be sent to SimPlot.
void plot(int data1, int data2)
  int pktSize;
  buffer[1] = 2*sizeof(int);      //Size of data in bytes. Does not include the header and size fields
  buffer[2] = data1;
  buffer[3] = data2;
  pktSize = 2 + 2 + (2*sizeof(int)); //Header bytes + size field bytes + data
//Function that takes 1 integer value and generates a packet to be sent to SimPlot.
void plot(int data1)
  int pktSize;
  buffer[1] = 1*sizeof(int);      //Size of data in bytes. Does not include the header and size fields
  buffer[2] = data1;
  pktSize = 2 + 2 + (1*sizeof(int)); //Header bytes + size field bytes + data
Then I generate two sine-waves with Audacity and recorded them with my Arduino via the microphone: The first sine-wave with 150Hz and the second with 800Hz.
Theoretically the first wave should pass and the second should be blocked. But both were reduced.
See attached pictures. I tried out other filters but without success. I`m not sure if the filters didn`t work or if I made errors at the sketch or library? If someone would have an idea it would be great.
Sorry for my bad English!
Thanks a lot: scjurgen; doggenj; Brijesh; for your work and publications!
thanks and greets
AdaZus
Magician
Quote
And what sampling freq. you expect to be?
AdaZus
Hello Magician,
many thanks your fast reply!
I changed the delay to 0.1ms and now it works! :)
My highest frequency that I want detect is ca. 400Hz. The sample frequency should be the double of the highest frequency, right? Sample frequency of 1000Hz?
But the filters should block also higher frequencies than 400Hz (to 20.000Hz). Do they work anyway?
Magician
Quote
Is it question? Who are they? I don't understand.
BTW, delay() function doesn't take float as an argument, you can't pass 0.1. Other things, you should measure how long does it take to call Filter.run()., it wouldn't be surprise if you don't need delay at all if filter eats up more than a few millisec.
AdaZus
My goal is to process only the frequencies from 0Hz to 400Hz while a band is playing. I`m not interested in the upper frequencies produced by the musical instruments. Afterwards I would love to program Bandpass filters to isolate singular notes. For example an "A" with 110Hz. But one step after another. Does it ok for my application to use a sample rate of 1000Hz?
I didn`t know that delay() function doesn't take float. Also I don`t know how to measure the time for calling "Filter.run()" or other orders in generally? I'm a newbie in programming.
Do you know perhaps other libraries or sketches with included Bandpassfilter?
I found your postings here:
http://forum.arduino.cc/index.php/topic,164915
but the web page:
http://coolarduino.wordpress.com/2012/06/28/stereo-audio-vu-meter-on-arduino/
sadly doesn`t exist anymore.
Magician
http://arduino.cc/en/Reference/HomePage
http://arduino.cc/en/Reference/Delay
This is how I measure timing :
Code: [Select]
  time_start = micros();
sampling();  //<- Filter.run() in your case
  time_sampl  = micros() - time_start;
Quote
Right, virus eats it up completely
AdaZus
Hello,
Now I have included the time measurement in my sketch. I hope I made it in the correct way…:
Code: [Select]
SimPlot Demo
int value;
int filtered;
int time_start;
int time_sampl;
  Filter.begin();
  Filter.setOrder(2);
int data1;
int data2;
int data3;
int data4;
  Serial.print("time_sample: ");     //time measurement and serial print
  time_start = micros();              //time measurement and serial print
  Filter.run(data1);                  //time measurement and serial print
  time_sampl = micros() - time_start; //time measurement and serial print
  Serial.println(time_sampl);        //time measurement and serial print
  //delay(1); //Read and plot analog inputs every 1ms.
  int pktSize;
  buffer[2] = data1;
  buffer[3] = data2;
  buffer[4] = data3;
  buffer[5] = data4;
  int pktSize;
  buffer[2] = data1;
  buffer[3] = data2;
  buffer[4] = data3;
  int pktSize;
  buffer[2] = data1;
  buffer[3] = data2;
  int pktSize;
  buffer[2] = data1;
So the time sample I measured is ca. 62us. See attachment. What do you think about?
Furthermore I tested the filter again whit a sweep from 0 to 1000Hz.The filter doesn`t work in the right way! The filtered signal is blocked (low amplitude) already at ca. 160Hz, but should be blocked only at 300Hz (filter design Lower Corner= 300Hz).  At ca. 390 the amplitude of the filtered signal increase and stay up until 700Hz.Than the filtered signal remain low until 870Hz. From 870Hz until 1000Hz the amplitude of the filtered signal is again at a high level.
What's wrong?
Magician
Have you visited Reference page? If so, than you should know that returned by micros() value is :
http://arduino.cc/en/Reference/Micros
Quote
Returns
Number of microseconds since the program started (unsigned long)
Than, you have also call to the plot() inside the loop, why you don't measure a time?
Third, serial print is slow, change your sketch in a way, that you keep timing measurements results in global variables, for example time_filter, time_plot etc, and print results ONLY by request.  Here is just an idea, not working code for you:
Code: [Select]
//  Serial.print("time_sample: ");     //time measurement and serial print
  time_filter = micros() - time_start; //time measurement and serial print
// Serial.println(time_sampl);        //time measurement and serial print
time_plot = micros() - time_start; //time measurement and serial print
  //CONSOLE COMMAND LINE INTERFACE
  if (Serial.available() > 0) {
    incomingByte = Serial.read();
    if (incomingByte == 'm') {             // FREE MEMORY BYTES
      Serial.println(freeRam());
    if (incomingByte == 'x') {
      for (int i = 0; i < FFT_SIZE; i++){
        Serial.print("\t");
        Serial.print( xin[i], DEC );
        if ((i+1)%16 == 0) Serial.print("\n");
      Serial.print("\n");
And last, doing measurements of sampling, you should discover that analogRead takes ~120 usec each, about 500 usec by 4 reads, so if loop contains sampling and nothing else inside, your maximum sampling rate is 2 kHz
AdaZus
Hello, yes I visited the page. I toke the example as reference. Firstly I used unsigned long but then I changed to int. Newbie error! ;)
I have to read out only one analog input (one microphone). (Now I commented it out in my sketch). So the theoretically maximum sampling rate is 8.333Hz (1.000.000us/120us). Many thanks for your example! I need some time to understand. Than hopefully we will see how much time it needs to call the filters.
AdaZus
Hello, I changed the code now as recommended:
Code: [Select]
// Arduino Signal Filtering an time measurement for Analog Read and Filter
SimPlot Demo
unsigned long time_start;
unsigned long time_sampl;
unsigned long time_plot;
int data1;
int data2;
//int data3;
//int data4;
int incomingByte = 0;
  Filter.begin();
  Filter.setOrder(2);
   data1 = analogRead(0);              //for analog 0
   data2 = Filter.run(data1);          // for filter calculation
  // time_start = micros();              //time measurement
//  time_plot = micros() - time_start; //time measurement
  // data3 = analogRead(2);
// data4 = analogRead(3);
//   plot(data1,data2,data3,data4);   //Plots 4 channels of data
    if (incomingByte == 'm') {             // press m and read time in microsec for Filter.run(data1)
      Serial.println(time_sampl, DEC);
    if (incomingByte == 'n') {             // press n and read time in microsec for plot(data1,data2)
      Serial.println(time_plot, DEC);
  int pktSize;
  buffer[2] = data1;
  buffer[3] = data2;
  buffer[4] = data3;
  buffer[5] = data4;
  int pktSize;
  buffer[2] = data1;
  buffer[3] = data2;
  buffer[4] = data3;
  int pktSize;
  buffer[2] = data1;
  buffer[3] = data2;
  int pktSize;
  buffer[2] = data1;
I hope I didn`t make big errors!
Explanation:
Only when I enter and send "m" (in serial monitor window) I get time measurement for "AnalogIn0" and "Filter.run(data1);". It gives me 172usec (attachment: Time_mes_plotoff). So theoretically I have a sample rate of 5.814Hz. I tried also to measure the time for „plot(data1,data2)", but it`s unreadable, because of all other symbols in the serial monitor window, read from real time plotting orders (attachment: Time_mes_ploton).
The thing is that I used the real-time-plot only to check if the filter works accurately. Maybe the right description of the problem I have now is the Heisenbug. Wikipedia: "Heisenbugs occur because common attempts to debug a program, such as inserting output statements or running it in a debugger, usually modify the code, change the memory addresses of variables and the timing of its execution."
In my end project I wouldn`t need the real-time-plot anymore. I want only that a LED switches on when a tone with a certain threshold (amplitude) passes the bandpassfilter. Maybe does it be also a good way to check if the filter library works fine? So with my lowpassfilter (cutoff frequency 300Hz) the LED should be shine until 300Hz and switched off with all frequencies above 300Hz.
Or do you know other, maybe more accurate methods to test the filters?
Magician
Quote
I'd create a big array, 256 or 512 values to store results of the filtering. Like in your initial setup, you feed a sinewave, arduino filterring data and store them to an array. You printing results by request whenever you change input, or like to observe a process.
I checked a library, and author's copy has this:
Code: [Select]
  if(_order==2) {                                 //ripple -1dB
    _v[0] = _v[1];
    _v[1] = _v[2];
    long tmp = ((((data * 662828L) >>  4)         //= (    7.901529699e-2 * x)
      + ((_v[0] * -540791L) >> 1)                 //+( -0.5157387562*v[0])
      + (_v[1] * 628977L)                         //+(  1.1996775682*v[1])
      )+262144) >> 19;                            // round and downshift fixed point /524288
    _v[2]= (int)tmp;
    return (int)((
      (_v[0] + _v[2])
      +2 * _v[1]));                               // 2^
As you can see, slow float math replaced by integer approximation.
You says:
Quote
Code:
  if(_order==2) {
         _v[0] = _v[1];
         _v[1] = _v[2];
         return
              (_v[0] + _v[2])
                 +2 * _v[1];
Is it code you are testing?
AdaZus
Yes, this was the filter code which I made my first tests. But after I also saw the error. Now I did some tests with this filter:
Code: [Select]
/// runChebyshev: Low Pass; 2nt Order; cutoff =300Hz; sampling=5000Hz; long type 8bit;
_v[0] = _v[1];
_v[1] = _v[2];
long tmp = ((((data * 5342655L) >>  5) //= (   3.9805879528e-2 * x)
+ ((_v[0] * -7243194L) >> 2) //+( -0.4317280064*v[0])
+ (_v[1] * 5337271L) //+(  1.2725044883*v[1])
)+2097152) >> 22; // round and downshift fixed point /4194304
_v[2]= (short)tmp;
return (short)((
(_v[0] + _v[2])
+2 * _v[1])); // 2^
I used "long type" whit 8 bit. Without "-1 bit saturation save".
Are that settings ok?
I have to do more tests but until now it doesn't work correctly.
Thank you very much for the Idea using a big array for filter validation!
AdaZus
Oh sry, it's a Bessel filter not a Chebyshev filter but it should work anyway..
Magician
Yea, coefficients looks o'k, except I didn't get
Quote
