I understand your guidelines, but, I added Serial.print lines after analogWrite, and the value that I send to the enable pin (in the L293) is 255, now, shouldn't that value make the motors run at full speed? I know there is a 1.5V drop in the L293, but I measured the voltage and it's 5V from a 7.5V battery, so the voltage drop is 2V!
AND the LEDS that I wired in parallel with those outputs bright dimly, so I guess 255 is not producing a 100% duty cycle. If I had an oscilloscope...
