Topic: Blink LED without using delay in the main loop (Read 5872 times) previous topic - next topic
yee0722
May 10, 2014, 08:52 am Last Edit: May 10, 2014, 10:56 am by yee0722 Reason: 1
Hi, I want to add blinking to my led, without using delay that will interrupt the overall system. The main loop has delay 3s, which will read temperature from sensor every 3s. I had try using example of "led blinking without delay", it was able to blink, but the blinking interval is not correct, it follows main loop delay, which not what I want.
I want the led to blink every 100ms in the 3s delay main loop.  Any ideas?
Code: [Select]
//declare variables
int buzzer = 5;
int yellow1 = 3;  //warning temp
int red1 = 4; // overtemp
int red = 2;  // red led indicate flame
float tempC;
float voltage;
int tempPin =0; // Temp sensor plugged analog pin 0
int flamePin= 1;
// write setup function
 Serial.begin(9600);// open serial port to communicate with the temp sensor
 pinMode(red1, OUTPUT);
 pinMode(yellow1, OUTPUT);
 pinMode (red, OUTPUT);
 pinMode (buzzer, OUTPUT);
//write loop that will control what we want the arduino to do with the sensor readout
 tempC = analogRead(tempPin); // taking the temp pin reading and setting it equal to tempC variable
 tempC = (5.0*tempC*100.0)/1024.0; // will convert the analog input to a temperature in celcius
 Serial.print((byte)tempC); //will output the converted temperature to pc
 Serial.println("02");  //xbee 2
 voltage = analogRead(flamePin);
 voltage = (5.0*voltage)/1023.0;
 Serial.print("0");
 Serial.print((byte)voltage);
 Serial.println("04"); //flame sensor from xbee2
 if (tempC>34)  //overtemp
    if (voltage <= 3)  //there is flame and temp >40, give fire alert!
   digitalWrite (red1, HIGH);  //overtemp
   digitalWrite (yellow1, LOW);  //overtemp
   digitalWrite (red, HIGH);  //flame detected
   digitalWrite (buzzer, HIGH); //give alert
   else  //temp>40, but no flame, possibility of false alarm
   digitalWrite(red, LOW); //RED led, no flame alert
   digitalWrite (red1, HIGH);  //high temp alert
   digitalWrite (buzzer, LOW);   //no alert
 else if ((tempC > 30) && (tempC <= 34))  //warning temp range
 if (voltage <= 3)  //there is flame and temp n warning range
   digitalWrite (yellow1, HIGH);  //overtemp
   digitalWrite (red1, LOW);  //overtemp
   else  //warning temp, but no flame, possibility of false alarm
   digitalWrite (yellow1, HIGH);  //high temp alert
   else  //not in warning range and no flame
   digitalWrite (yellow1, LOW);  //YELLOW led, no high temp alert
 delay(3000);
PaulRB
Hi, have you read and understood the "Blink Without Delay" example sketch?
Paul
PaulRB
Ah, you edited your original post while I was replying...
The point of the BWD sketch is the principal of checking if a desired period has passed and taking an action when it has. In your case you have 2 desired periods: one of 3 secs and the other of 100ms. You have to keep track separately of the time each of those two periods began, and test separately for the end of either/both periods.
PaulRB
Post your sketch with the attempt to use the BWD principle.
yee0722
below is use the principle of blink without delay.. I know somewhere wrong but no ideas how to correct it.. because it involve two timing.. it can blink but blink with the delay in main loop. Any ideas? I just try it on yellow led only.
Code: [Select]
//declare variables
int buzzer = 5;
float tempC;
float voltage;
int flamePin= 1;
int yellow1state = LOW;
long previousMullis = 0;
long interval = 100;
 Serial.print("0");
   ///////////////////////////// yellow1 start blink
 if(currentMillis - previousMillis > interval) {
   // save the last time you blinked the LED
   // if the LED is off turn it on and vice-versa:
   if (yellow1State == LOW)
     yellow1State = HIGH;
     yellow1State = LOW;
   // set the LED with the ledState of the variable:
   digitalWrite(yellow1, yellow1State);
 delay(3000);
PaulRB
#5
May 10, 2014, 10:04 am Last Edit: May 10, 2014, 10:08 am by PaulRB Reason: 1
Your post subject says "without using delay in main loop". So you already know what you need to do. There must be a reason why you have not done it, can you explain please?
Also I can see a spelling error in that sketch, it cannot have been tested.
I do not see any code there for testing if 3 seconds has passed and it is time to read your sensors again.
yee0722
okok.. I know what you means..  :smiley-roll-sweat: My title should "Blink LED without using delay in a delay main loop"....
I don't want to delete the delay in main loop..  :~
yee0722
Sorry my mistake on the typo in the sketch, here it is. No error detected.
Code: [Select]
//declare variables
int buzzer = 5;
float tempC;
float voltage;
int flamePin= 1;
int yellow1State = LOW;
long previousMillis = 0;
  Serial.print("0");
    digitalWrite (yellow1, HIGH);  //warning on
    digitalWrite (red1, LOW);  //overtemp off
      yellow1State = LOW;
  delay(3000);
yee0722
Sorry sir, what you means? I have delay at the last line "delay(3000)" in the main loop to read sensor every 3s.
Hackscribble
The reason PaulRB suggested using "blink without delay" is that the delay() function holds up the program for the length of the delay.  No other processing gets done!  So while your code is in the delay(3000), it cannot blink the LED.
You need to remove the delay(3000) and add code to measure 3 seconds using the same technique as flashing the LED.  Then check your sensors each time the 3 seconds ends.
Hackscribble.  Writing about making things
hackscribble@outlook.com
yee0722
Sorry sir, what code should I add to replace the delay(3000)?
PaulRB
Why?
If you must keep that delay, you could replace your 3s delay with a loop that repeats 15 times. Inside the loop, swich your led on, delay for 100ms, switch your led off and delay another 100ms.
yee0722
ok sir, I know what you means.. i need do something on the main loop to read the sensor every 3s without using delay. Can you give me some hints on how to modify my sketch?
AWOL
Quote
In the IDE there's an example called "blink without delay".
Read it, play with it, understand it.
And don't be blinkered by the word "blink" - the action could be anything.
PaulRB
I already did in my second post above.
Please don't call me sir...
