Topic: [Help] Stepper motor, arduino mega 2560, easy driver. (Read 1 time) previous topic - next topic
tony_tran
May 15, 2014, 12:25 pm Last Edit: May 15, 2014, 12:42 pm by tony_tran Reason: 1
Hi everybody,
I have stepper motor type: 42GBY023-20, 12V, 0.4A, 200 steps, 6 wires  and i use arduino mega 2560 with Easy driver, my power for stepper motor is 12V, 0.5A and use laptop for arduino mega.
When i use this code:
#include <Stepper.h>
const int stepsPerRevolution = 200;  // change this to fit the number of steps per revolution
                                    // for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8,9);
 // set the speed at 60 rpm:
 myStepper.setSpeed(60);
 // initialize the serial port:
 // step one revolution  in one direction:
  Serial.println("clockwise");
 myStepper.step(stepsPerRevolution);
  // step one revolution in the other direction:
 Serial.println("counterclockwise");
 myStepper.step(-stepsPerRevolution);
my stepper motor not working like this : "// set the speed at 60 rpm:"  it's only turning left and turning right at the same position. I try to change other code and change the way to connect wire from motor to easy driver but not working, only vibrate.
I don't know why, please help me !
Thank you all,
Tony.
Robin2
This simple code should make it work - just to prove that it does.
Code: [Select]
// testing a stepper motor with a Pololu A4988 driver board or equivalent
// on an Uno the onboard led will flash with each step
// as posted on Arduino Forum at http://forum.arduino.cc/index.php?topic=208905.0
byte directionPin = 9;
byte stepPin = 8;
int numberOfSteps = 100;
byte ledPin = 13;
int pulseWidthMicros = 20;  // microseconds
int millisbetweenSteps = 25; // milliseconds
  Serial.println("Starting StepperTest");
  digitalWrite(ledPin, LOW);
  delay(2000);
  pinMode(directionPin, OUTPUT);
  pinMode(stepPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(directionPin, HIGH);
  for(int n = 0; n < numberOfSteps; n++) {
    digitalWrite(stepPin, HIGH);
    delayMicroseconds(pulseWidthMicros);
    digitalWrite(stepPin, LOW);
    delay(millisbetweenSteps);
    digitalWrite(ledPin, !digitalRead(ledPin));
  delay(3000);
  digitalWrite(directionPin, LOW);
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
tony_tran
Thank you, Robin2. After i check, it's still not working. Nothing move...
Robin2
Then please draw a clear diagram showing how everything is connected and post a photo of the drawing.
Also give details of what power supply you are using for the motor.
...R
