Below simple serial code for sending data from one arduino to another. An ethernet connection might be of interest if video from the ROV is desired.
//zoomkat 3-5-12 simple delimited ',' string tx/rx
//from serial port input (via serial monitor)
//and print result out serial port
//Connect the sending arduino rx pin to the receiving arduino rx pin.
//Connect the arduino grounds together.
//What is sent to the tx arduino is received on the rx arduino.
//Open serial monitor on both arduinos to test
String readString;
Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
//expect a string like wer,qwe rty,123 456,hyre kjhg,
//or like hello world,who are you?,bye!,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
if (readString.length() >1) {
Serial.print(readString); //prints string to serial port out
Serial.println(','); //prints delimiting ","
//do stuff with the captured readString
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
