I'm having trouble uploading a sketch on my Pro mini AT328 5V 16 MHZ that I got from SparkFun.
I'm using an FTDI TTL-232R-5V-WE cable that supplies 5V. I have wired it up as follows:
green - green
yellow - TX0
orange - RXI
red - VCC
brown - GND
black - BLK
If i try to upload in "verbose" mode by holding down the shift key then pressing upload i get this:
avrdude: usbdev_open(): did not find any USB device "usb"
If I do it in normal mode I get this:
avrdude: stk500_getsync(): not in sync: resp=0x00
I have tried pressing the reset button at various times.
I have done the loopback test posted at the top of this forum, that FAILED. However I have also done my own loopback test by jumping TX and RX and CTS and RTS, that PASSED. I don't know what this means.
I have set the "set RTS on close" in the advanced settings on the COM port.
I have verified the Board setting in the IDE. I have tried Pro mini / pro at328 5v 16mhz as well as what was suggested in the troubleshooting guide of using Duemilnove at328.
I have verified the com port is correct in the IDE setup
I have Verified the drivers are up to date for the FTDI cable-at least according to Windows 8.1 - Does 8.1 suffer from the same ailments as Win7?
I have tried two different Pro Mini's and one of my Pro's
All three seem to have a bootloader installed because I do get a blink on the LED when I press the reset button. They came from SparkFun if that makes any difference?
I have tried most of the above on my windows XP machine as well with the same results.
I bought a Lilypad Snap thingee from sparkfun a while that had the demo sketch, but no bootloader. Didn't break out the SPI pins so no way load the bootloader without a special TQFP adapter.
Do you have a working Uno? Can set that up as an ISP and put a bootloader onto your Promini's:
Could also try updating the FTDI driver: http://www.ftdichip.com/Drivers/D2XX.htm
Win x64-bit (or 32-bit, but not likely with newer machine)
Another member reported success with this yesterday.
These are the only Arduino's I have. I do have a few jtag programmers for Silicon labs parts and NXP. I'll see what else I have and maybe contact SparkFun too.
The Arduino IDE needs the VCP driver doesn't it? I'm using the latest version of the Arduino IDE 1.0.5-r2.
I downloaded the VCP and the D2XX, either way windows is convinced i have the most up to date driver. The Driver version in Device manager for my COM port does match whats listed on FTDI's website as being the latest. 2.10.0
I guess all that left is to get the bootloader reloaded....
EDIT: I tried it on my Win8.1 and my XP machine, still nothing. The Arduino IDE 1.0.5-r2 on Win8.1 is REALLY slow. I do not have any of the Bluetooth serial drivers mentioned in one of the troubleshooting guides. I went ahead and disabled my Bluetooth radio anyway since I don't use it, its still slow..
I am having the identical problem with using my sparkfun ftdi device to program my pro mini board "avrdude: stk500_getsync : not in sync: resp = 0x00". I have ordered two different versions of the pro mini and both devices exhibit the same unwillingness to be programmed. My sparkfun device did work successfully on a bare atmega328 with the arduino bootloader.
It seems I have been using the wrong cable. I thought mine was a USB to TTL. It appears that it is actually a USB to RS232. I have ordered a TTL version and will have it tomorrow. I will report back once I get it.
