Arduino Forum
Using Arduino
Installation & Troubleshooting
I reversed gnd and vin...
Pages:
[1]
Topic: I reversed gnd and vin...
(Read 1 time)
previous topic
next topic
BluePhoenix
Guest
May 17, 2014, 03:31 pm
Last Edit
: May 17, 2014, 03:34 pm by BluePhoenix
Reason
: 1
I've connected the gnd to 7.2v and the pin vin to the minus of the battery... as result the chip near the DC power connector blow up!
Ok... now I have two questions
1-Which is the name of the chip? There's written something like 113nf
2-Is that chip the only thing I broke?
I'm so afraid T_T
BluePhoenix
Guest
Re: I reversed gnd and vin...
#1
May 17, 2014, 03:51 pm
I'm using an arduino UNO r3
CrossRoads
Unlimited Eagle board sizes available.
[add]
Author of "Arduino for Teens". Available for Design & Build services. Now with Unlimited Eagle board sizes!
http://www.crossroadsfencing.com/BobuinoRev17/
#2
May 17, 2014, 06:38 pm
Post a picture. I find this works well: copy from the product page, paste into powerpoint, draw an arrow, save as .jpg.
Then clickk Additional Options, Browse to your file, and Attach it.
Designing & building electrical circuits for over 25 years. Screw Shield for Mega/Due/Uno, Bobuino with ATMega1284P, & other '328P & '1284P creations & offerings at my website.
BluePhoenix
Guest
#3
May 17, 2014, 06:45 pm
Quote from: CrossRoads on May 17, 2014, 06:38 pm
Post a picture.
Thanks for your reply, I hope to find a solution in order to not buy another arduino
There are 4 arrows in the left-bottom corner
retrolefty
[add]
Measurement changes behavior
#4
May 17, 2014, 07:18 pm
You likely damaged other stuff on the board sensitive to having reverse polarity applied. It will take some time and expense to replace the obviously bad component(s) only to see that the board still doesn't work.
That is too bad because if you had applied the reverse polarity to the external power connector instead of directly to the shield Vin pin you would have suffered no damage because the arduino folks installed a reverse polarity protection diode between the connector and the Vin trace just for such newbie type of mistake.
CrossRoads
[add]
#5
May 17, 2014, 07:41 pm
That part is the 5V regulator.
http://www.digikey.com/product-detail/en/NCP1117ST50T3G/NCP1117ST50T3GOSCT-ND/1967217
Remove it, then measure with an ohm meter between +5 and Gnd. Should see a pretty high resistance, like 10s of K-ohms. If not, remove the 328 chip & measure again. If still low, then something else surface mount is damaged - could be the 16U2 USB/Serial chip, the 3.3V regulator, the op-amp, the FET T1 that does the autoswitching.
http://arduino.cc/en/uploads/Main/Arduino_Uno_Rev3-schematic.pdf
BluePhoenix
Guest
#6
May 19, 2014, 04:18 pm
Ok... i removed the burnt chip and now (via usb and via 5v pin) it works! In a few days I will buy some reg sot223 5v
I will notice you about what will happen
CrossRoads
[add]
#7
May 20, 2014, 11:21 pm
Make sure the part you purchase has the same pinout as what's on the board.
BluePhoenix
Guest
#8
May 22, 2014, 08:43 pm
The only reg I found here, in Italy is a sot-223 5v BUT the pin out is input-gnd-output :~ :~ :~
CrossRoads
[add]
#9
May 22, 2014, 10:07 pm
Keep looking then. Or, use a leaded part, and bend the pins to end up where needed.
Or get a 5V wallwart, and jumper over the regulator pads (and reverse polarity diode).
Or get a USB wallwart, and power the board thru the USB port.
Pages:
[1]
