Topic: instructions for multifunction board (Read 41456 times) previous topic - next topic
matelot
I can't find a heading for my subject so I hope I am not going to get too much flak if I put it here.
I am interested in getting a multifunction board
http://www.ebay.co.uk/itm/Multifunctional-Expansion-Board-Shield-kit-Based-Learning-for-Arduino-UNO-R3-WT/171286049290?_trksid=p5411.c100167.m2940&_trkparms=aid%3D222006%26algo%3DSIC.FITP%26ao%3D1%26asc%3D20140131123730%26meid%3D7035883307498581842%26pid%3D100167%26prg%3D20140131123730%26rk%3D3%26rkt%3D15%26sd%3D231195379846
I notice there is no paperwork with it.
Does anyone know of anywhere I could get instructions i.e, which pin goes to which fiunction?
thanks.
Bob.
knut_ny
Ny
matelot
no documentation..=> trouble ahead
I disagree. For me no documentation means I have to look and one of the ways to look is to get advice from a forum.
Comments like yours are defeatist as well as unwarranted.
I looked and found
http://www.baaqii.com/promanage/manual/A1010.zip
Which is exactly what I wanted.
matelot
has anyone seen any tutorials for this board anywhere?
I am interested in the socket on the top left (wi-fi, i/r, temperature sensor etc)
CrossRoads
Can you unzip, use Additional Options, Browse to your locally stored copy, and Attach the file?
knut_ny
The header (APC220) feeds power to the radio on pins 1 &2 and connects RX/TX to Arduino pins 0&1
Ny
jones_mp
Hi, the link to the manual does not seem to be working.  Could it be updated or  a new link,provided please.
Cheers, Martyn
jones_mp
Well the link is working now so thanks for that. Is there an English translation of the manual available anywhere please? Or has anyone done any work on working out the connections and how to use the multifunction board? Any help will be much appreciated. Cheers, Martyn.
matelot
#8
Aug 04, 2014, 12:56 am Last Edit: Aug 04, 2014, 12:59 am by matelot Reason: 1
I didn't ask for the manual . All I was wanting was the pin layouts. The link I quoted included a pdf file
which I have attached.
Is this what you wanted Bob?
CrossRoads
Yes, thanks.  I was probably at work and couldn't access that.
The pin layouts are shown in the PDF okay. The Arduino header numbers are scattered around to the components  (either digital, 0 to 13 with PWM markings, A0 to A5). Some buttons with pullup resistors, some LEDs with current limit resistors, some headers with +5/Gnd to connect to off board pots or sensors or servos (PWM signals), an onboard pot, an onboard buzzer it looks like, couple of shift registers for multiplexing 7-segment displays, an on board DS1820 (thermal sensor?)
and one part on the serial lines with characters I don't know how to translate. Can't even copy/paste into google for a translation.
CrossRoads
Did you go thru the other folder? Has a bunch of arduino sketches.
The code is readable, the comments need translating.
First several seem pretty standard, blink the LEDs, button presses, etc.
I can't get to e-bay at work, so I skip over posts with links to e-bay products.
matelot
#11
Aug 04, 2014, 01:02 pm Last Edit: Aug 04, 2014, 01:07 pm by matelot Reason: 1
no, I have tried to translate them. they don't come off the pdf sheet. I will try to find someone to translate them for me ^_^
The comments on the sketches do translate but it would be a big job to go through all of them . I have sent a message to the company I got the files from (in China) asking if they know of an English version.
edit :- the Chinese alongside  the 7 pin plug converts as
 'connect for wireless module'.
On the board it says
'APC200 bluetooth voice recognition module'.
Does that sound familiar?
knut_ny
APC220 radio will plug in directly.
Ny
CrossRoads
matelot
thanks Bob.
I have just had a reply from my source, they know of no English version of the sketches with the Chinese comments.
I may go through them at some time.
If anyone wants a project please let me know  :smiley-roll:
