Topic: How do I change the baud rate? (Read 6412 times) previous topic - next topic
robtillaart
Quote
I only have 1 Serial port. GSM shield uses pin number 2 and 3.
That means you hardware serial port (pin 0 and 1 ) uses the BLE right?
The GSM shield uses pin 2,3
So you only need to set the baud rate once for the BLE (115200) and once for the GSM (9600)
I'll do a quick scan of your code (I'll be back ;)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
I see that PINNUMBER is defined as an empty "" -> I think a number should be in probably 2 or 3
#define PINNUMBER ""
Also your code has much comments that do not add value ==> remove it as it will only distract.
usage of better variable /function names makes most comments obsolete
//GSM gsmAccess;  <<<<<<<<<<<<<<<<< no value as it just is an echo of the line beneath
GSM gsmAccess(true);
char remoteNum[20] = "98997412";  // telephone number to send sms
so why not
char telephoneNumber[20] = "98997412";
no comments needed as the code becomes self explaining.
char txtMsg[200] = "Your device is out of range."; //sms content <<<<<<<<<<<< ??
char smsContent[200] = "...";
or
chat textMessage[200] ...
  slaveConfiguration(); //BLE configuration for slave
  BLEslaveConfiguration();
etc
Rob Tillaart
visualxl
Yes you are right on that. Pin 0 and 1 is for the BLE.
Quote
So, how do i do that ya especially for the GSM shield?
robtillaart
Quote
Quote
as I said
Quote
what GSM library do you use?
Rob Tillaart
visualxl
That is not right.
Code: [Select]
PINNUMBER = ""; //PIN on the SIM card if there is. Optional.
I am using this GSM library.
http://arduino.cc/en/Reference/GSM
fungus
The GSM is already using a SoftwareSerial internally on Pin number 2 and 3. Otherwise, It won't be able to send the SMS right? :)
So...you don't actually need to change the baud rate at all.
GSM does its own thing - you don't control it.
BLE needs 115200 which you can do once in setup().
Advanced Arduino
visualxl
That's what I don't understand.
If I set the Serial to 115200, I cannot configure or make the GSM work ~ T_T
fungus
OK, so that's what you need to figure out...
Advanced Arduino
robtillaart
looked in the GSM lib (oops its huge...)
if your board is a UNO (??)  it seems that the GSM uses a own soft-serial implementation to escape certain bytes.
This library is automatically initialized to 9600 baud if I understand code correctly.
So you do not need to set the baud rate yourself.
Rob Tillaart
visualxl
Yeap. We are on the same channel.
I just got it to work on Serial 115200. I think it may be good that I share this here. See if it may help others or not.
My purpose is to send an SMS once if RSSI is 0. Lemme clear a couple of stuff first with my superiors. :)
