After some days of tinkering with my code, I am pleased to say that I think I have reached an acceptable level of randomness in the mapped values!
I implemented your suggestion to limit bit-length and toss out any number greater than my maximum required value, and it seems to work well. The map20() method I used which was based on your algorithm does not work, and I can't figure out why, but this method does seem to.
Thank you very much for your help! If you have any other input or notes for me, I would be glad to hear them.
#define BINS_SIZE 256
#define CALIBRATE_SIZE 10000
#define NO_BIAS_REMOVAL 0
#define EXCLUSIVE_OR 1
#define VON_NEUMANN 2
#define ASCII_BYTE 0
#define BINARY 1
#define ASCII_BOOL 2
#define BYTE_LENGTH 8
#define LONG_NIBBLE_LENGTH 5
#define NIBBLE_LENGTH 4
#define TWO_BIT_LENGTH 2
#define COIN_FLIP 1
#define MAP_MAX 20
#define LED_PIN 13
#define ADC_PIN A0
/*** Configure the RNG **************/
int bias_removal = VON_NEUMANN;
boolean TWO_LEVEL_WHITENING = true;
int output_format = ASCII_BOOL;
int max_length = LONG_NIBBLE_LENGTH;
boolean mapResults = true;
unsigned long maxSamples = 500000;
int baud_rate = 19200;
unsigned int Bins[BINS_SIZE];
unsigned int Results[MAP_MAX];
boolean initializing = true;
unsigned int calibration_counter = 0;
boolean bufferFull = false;
byte buffer = 0;
byte threshold = 0;
unsigned long samples = 0;
void setup(){
pinMode(LED_PIN, OUTPUT);
Serial.begin(baud_rate);
for (int i=0; i < BINS_SIZE; i++){
Bins[i] = 0;
for (int i=0; i < MAP_MAX; i++){
Results[i] = 0;
analogReference(EXTERNAL);
void loop(){
Serial.println("Initializing...");
Serial.println("Calibrating...");
threshold = calibrate();
Serial.print("Threshold: ");
Serial.println(threshold);
delay(2000);
Serial.println("Collecting Data");
Bins[i] = 0;
while(samples < maxSamples)
byte rand = getRandomByte(threshold);
if(mapResults)
if(rand < MAP_MAX)
Results[rand]++;
samples++;
Serial.print(samples);Serial.print(": ");Serial.println(rand);
Bins[rand]++;
samples++;
Serial.println("Distribution:");
Serial.print(i);
Serial.print(": ");
Serial.println(Bins[i]);
for (int i=0; i < 20; i++){
Serial.print(i);
Serial.print(": ");
Serial.println(Results[i]);
while(true){
byte getRandomByte(byte tHold)
while(!bufferFull)
int adc_value = analogRead(ADC_PIN);
byte adc_byte = adc_value >> 2;
processInput(adc_byte, tHold);
bufferFull = false;
return buffer;
void processInput(byte adc_byte, byte threshold){
boolean input_bool;
input_bool = (adc_byte < threshold) ? 1 : 0;
switch(bias_removal){
case VON_NEUMANN:
vonNeumann(input_bool);
case EXCLUSIVE_OR:
exclusiveOr(input_bool);
case NO_BIAS_REMOVAL:
buildByte(input_bool);
void exclusiveOr(byte input){
static boolean flip_flop = 0;
flip_flop = !flip_flop;
buildByte(flip_flop ^ input);
void vonNeumann(byte input){
static int count = 1;
static boolean previous = 0;
if(flip_flop){
if(input == 1 && previous == 0){
if(TWO_LEVEL_WHITENING)
exclusiveOr(0);
buildByte(0);
else if (input == 0 && previous == 1){
exclusiveOr(1);
buildByte(1);
previous = input;
void buildByte(boolean input){
static int byte_counter = 0;
static byte out = 0;
if (input == 1){
out = (out << 1) | 0x01;
else{
out = (out << 1);
byte_counter++;
byte_counter %= max_length;
if(byte_counter == 0){
buffer = out;
bufferFull = true;
out = 0;
return;
bufferFull = false;
unsigned int calibrate()
digitalWrite(LED_PIN,HIGH);
for(int i = 0; i < CALIBRATE_SIZE; i++)
byte analog = adc_value >>2;//truncates to 0-255
Bins[analog]++;
//find the median
unsigned long half;
unsigned long total = 0;
int i;
for(i=0; i < 256; i++){
total += Bins[i];
half = total >> 1;
total = 0;
total += Bins[i];
if(total > half){
digitalWrite(LED_PIN,LOW);
return i;
