Topic: Problem reading random noise generator (Read 11871 times) previous topic - next topic
acegard
I am very fond of the debugging approach of throwing away the parts of code that aren't working for me, and either recoding from scratch or even better trying a different approach/algorithm.
Me too! I have rewritten and refactored this sketch four or five times since the inception of the project. I have since layered XOR whitening on top of the Von Neumann, and am currently implementing the Jenkins hash you provided. It's making the 0-255 distribution improve each time, but not the mapped distribution, which remains pretty terrible. I would be surprised if it's something in your algorithm, because I've seen the vast and corroborated results of your tests.
wanderson
Ok, I have collected about 75,000 numbers from 0-19, using my original library code.  Looks like the algorithm itself is working (chi sq of 29.9283, p-value of 0.05272, so when I get finished playing with my new 3D printer that just arrived I will look at seeing what is wrong with your code in a day or two!
> library(foreign)
> tmp <- read.csv("log20.txt")
> tmp <- tmp$X3
> cb <- table(tmp)
> pb <- rep(1/20,20)
> cb <- as.integer(cb)
> chisq.test(cb, p = pb)
Chi-squared test for given probabilities
data:  cb
X-squared = 29.9283, df = 19, p-value = 0.05272
> length(tmp)
[1] 73958
> sum(cb)
[1] 73958
acegard
Great! Have fun with the printer! I'll keep posting things as I run tests or figure out what is wrong.
acegard
After some days of tinkering with my code, I am pleased to say that I think I have reached an acceptable level of randomness in the mapped values!
I implemented your suggestion to limit bit-length and toss out any number greater than my maximum required value, and it seems to work well. The map20() method I used which was based on your algorithm does not work, and I can't figure out why, but this method does seem to.
Thank you very much for your help! If you have any other input or notes for me, I would be glad to hear them.
#define BINS_SIZE 256
#define CALIBRATE_SIZE 10000
#define NO_BIAS_REMOVAL 0
#define EXCLUSIVE_OR 1
#define VON_NEUMANN 2
#define ASCII_BYTE 0
#define BINARY 1
#define ASCII_BOOL 2
#define BYTE_LENGTH 8
#define LONG_NIBBLE_LENGTH 5
#define NIBBLE_LENGTH 4
#define TWO_BIT_LENGTH 2
#define COIN_FLIP 1
#define MAP_MAX 20
#define LED_PIN 13
#define ADC_PIN A0
/***  Configure the RNG **************/
int bias_removal = VON_NEUMANN;
boolean TWO_LEVEL_WHITENING = true;
int output_format = ASCII_BOOL;
int max_length = LONG_NIBBLE_LENGTH;
boolean mapResults = true;
unsigned long maxSamples = 500000;
int baud_rate = 19200;
unsigned int Bins[BINS_SIZE];
unsigned int Results[MAP_MAX];
boolean initializing = true;
unsigned int calibration_counter = 0;
boolean bufferFull = false;
byte buffer = 0;
byte threshold = 0;
unsigned long samples = 0;
void setup(){
  pinMode(LED_PIN, OUTPUT);
  Serial.begin(baud_rate);
  for (int i=0; i < BINS_SIZE; i++){
    Bins[i] = 0;
  for (int i=0; i < MAP_MAX; i++){
    Results[i] = 0;
  analogReference(EXTERNAL);
void loop(){
  Serial.println("Initializing...");
  Serial.println("Calibrating...");
  threshold = calibrate();
  Serial.print("Threshold: ");
  Serial.println(threshold);
  delay(2000);
  Serial.println("Collecting Data");
    Bins[i] = 0;
  while(samples < maxSamples)
    byte rand = getRandomByte(threshold);
    if(mapResults)
      if(rand < MAP_MAX)
        Results[rand]++;
        samples++;
        Serial.print(samples);Serial.print(": ");Serial.println(rand);
      Bins[rand]++;
      samples++;
  Serial.println("Distribution:");
    Serial.print(i);
    Serial.print(": ");
    Serial.println(Bins[i]);
  for (int i=0; i < 20; i++){
    Serial.print(i);
    Serial.print(": ");
    Serial.println(Results[i]);
  while(true){
byte getRandomByte(byte tHold)
  while(!bufferFull)
    int adc_value = analogRead(ADC_PIN);
    byte adc_byte = adc_value >> 2;
    processInput(adc_byte, tHold);
  bufferFull = false;
  return buffer;
void processInput(byte adc_byte, byte threshold){
  boolean input_bool;
  input_bool = (adc_byte < threshold) ? 1 : 0;
  switch(bias_removal){
  case VON_NEUMANN:
    vonNeumann(input_bool);
    break;
  case EXCLUSIVE_OR:
    exclusiveOr(input_bool);
    break;
  case NO_BIAS_REMOVAL:
    buildByte(input_bool);
    break;
void exclusiveOr(byte input){
  static boolean flip_flop = 0;
  flip_flop = !flip_flop;
  buildByte(flip_flop ^ input);
void vonNeumann(byte input){
  static int count = 1;
  static boolean previous = 0;
  if(flip_flop){
    if(input == 1 && previous == 0){
      if(TWO_LEVEL_WHITENING)
        exclusiveOr(0);
        buildByte(0);
    else if (input == 0 && previous == 1){
        exclusiveOr(1);
        buildByte(1);
  previous = input;
void buildByte(boolean input){
  static int byte_counter = 0;
  static byte out = 0;
  if (input == 1){
    out = (out << 1) | 0x01;
  else{
    out = (out << 1);
  byte_counter++;
  byte_counter %= max_length;
  if(byte_counter == 0){
    buffer = out;
    bufferFull = true;
    out = 0;
    return;
  bufferFull = false;
unsigned int calibrate()
  digitalWrite(LED_PIN,HIGH);
  for(int i = 0; i < CALIBRATE_SIZE; i++)
    byte analog = adc_value >>2;//truncates to 0-255
    Bins[analog]++;
  //find the median
  unsigned long half;
  unsigned long total = 0;
  int i;
  for(i=0; i < 256; i++){
    total += Bins[i];
  half = total >> 1;
  total = 0;
    total += Bins[i];
    if(total > half){
      break;
  digitalWrite(LED_PIN,LOW);
  return i;
wanderson
Glad to here you got the code working.  I am still climbing the 3D printing learning curve!
