Topic: Can't upload sketches to my homemade arduino (Read 2169 times) previous topic - next topic
simonepsp
Jun 01, 2014, 12:15 pm Last Edit: Jun 01, 2014, 12:20 pm by simonepsp Reason: 1
I made this arduino for a school project but I can't get it to work. In fact I can't upload sketches into.
That's what I have:
- Arduino serial2USB light adapter ( http://arduino.cc/en/Main/USBSerial)
- My custom arduino PCB
- Arduino 1.0.5
What I'm trying to do:
I'm trying to upload a sketch on it using Arduino IDE and Arduino's Serial2USB Light Adapter.
Error I get on Arduino IDE
avrdude: stk500_getsync(): not in sync: resp=0x00
Notes
- Drivers are installed correctly and COM is successfully set.
- ATMEGA 328P-PN is already programmed with Optiboot
- When I press Reset button nothing happens.
SERIAL- PCB CONNECTIONS
5V- 5V
GND-GND
TX-RX
RX-TX
RESET/EXT-  DTR
PCB SCHEMATICS
If you need further informations please ask :)
Thank you for your help
spycatcher2k
You don't have your reset pin connected to anything that will reset the chip!
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
simonepsp
thanks. What should I do to fix this error?
spycatcher2k
refer to the reference schematic at http://arduino.cc/en/uploads/Main/Arduino_Uno_Rev3-schematic.pdf
Mrs Drew
simonepsp
so there's a problem with reset button? :| I don't understand
spycatcher2k
Pin 1 of the 328 does not have any way to pull it LOW for a RESET.
Mrs Drew
simonepsp
sorry, I'm not an electronic and I don't understand what should I do :)
Could you explain me ?
Thank you :)
simonepsp
#7
Jun 01, 2014, 05:52 pm Last Edit: Jun 01, 2014, 05:58 pm by simonepsp Reason: 1
I'm using a jumper to connect DTR  to RESET pin and ATMEGA 1st PIN (RESET).
I've also used a capacitor and a 10kOhm res.
What is wrong?
(see first image on first post :) )
simonepsp
Found a fix! There was a connection problem with OSC.
Here's the solution (many thanks to Christian Aschoff of Fritzing forum):
http://fritzing.org/forum/thread/3394/?page=last
