Topic: Encoders which one do you advice me to buy? (Read 1 time) previous topic - next topic
tahmod
I search in ebay and hobbytronic for encoders, below are the one I found
http://www.ebay.co.uk/itm/2-Speed-Measuring-Module-HC-020K-w-Photoelectric-Encoders-for-Experiment-/400547392351?pt=UK_BOI_Industrial_Automation_Control_ET&hash=item5d427c2b5f
http://www.hobbytronics.co.uk/optical-encoder-kit-5v?keyword=encoder
CrossRoads
TomGeorge
Hi.
The ebay units, each unit will give you speed type readings, as in pulses per time, but not direction , so it is not an encoder, it is a chopper or interrupter unit.
The HT is a quadrature encoder, each unit will give speed, and direction if you use both of the outputs. This is what is special about a quadrature encoder.
So it depends if you want speed, or speed and direction detection.
Hope this helps.
Tom....... :)
Everything runs on smoke, let the smoke out, it stops running....
