Topic: Arduino Nano Soft serial interface problem (Read 5309 times) previous topic - next topic
sreenivas
Dear  friends
Recently i have started working on Arduino Nano, my code is below , i un able to transmit & get the data on "soft serial "
Does soft serial work for Arduino Nano? Please let me know friends
#include <SoftwareSerial.h>
SoftwareSerial mySerial =  SoftwareSerial(10, 11);
// D6, D7 on board
    while (!Serial) {
     ; // wait for serial port to connect. Needed for Leonardo only
      Serial.println("Goodnight moon!"); // it is printing on Serial monitor teminal
     mySerial.begin(9600);
      mySerial.write('H'); // soft sending
      char read_char = mySerial.read(); // soft reading
      if(read_char == 'H') // comparing soft read data
                 Serial.println("Soft Serial is Working"); // it has to print on soft terminal
Hackscribble
Hi sreenivas
Code: [Select]
// D6, D7 on board
I'm confused by the comment.  On the Nano board, what are the labels by the pins you are using for SoftwareSerial?
Regards
Ray
Hackscribble.  Writing about making things
hackscribble@outlook.com
PaulS
sreenivas
#3
Jun 06, 2014, 06:39 am Last Edit: Jun 06, 2014, 07:03 am by sreenivas Reason: 1
Hi sreenivas
Code: [Select]
// D6, D7 on board
Regards
Ray
Dear Ray,
Pins (10,11)  =  PD6, PD7 (of MCU) = D6,D7 (Marked on Nano board).
when i short / join them (D6,D7) , Code should print "Soft Serial is Working" on Serial Monitor.
Let me know whats wrong in my  process.
sreenivas
#4
Jun 06, 2014, 06:49 am Last Edit: Jun 06, 2014, 07:05 am by sreenivas Reason: 1
What are you trying to talk to?
Dear Paul,
Sorry i did not mentioned the problem,
when i short / join them D6, D7 ( MCU pins 10,11 ), Code should print "Soft Serial is Working" on Serial Monitor.
but its not. i observed read char is getting the value (-1).
Hackscribble
If you are using digital pins 6 and 7 of Nano, try 6 and 7 in SoftwareSerial statement.
sreenivas
Dear friend
i tried as below ,  even though its not working as i expected
i am using
IDE             : Arduino 1.0.5-r2
Hardware: Arduino Nano
Let me know any modifications to be done
SoftwareSerial mySerial(10,11);
// Trial 1
// shorted D6, D7, output on serial monitor is
// Goodnoght moon!
// -1A-1A-1A
// Trial 2
// shorted D10, D11, output on serial monitor is
// Goodnoght moon!
// -1A-1A-1A
//(same output in both the cases)
  mySerial.print('H'); // Soft serial print
  Serial.print(mySerial.read());// Hard serial print after reading soft serial byte, here its printing  "-1"
  Serial.print('A'); //Hard serial print "A"
  mySerial.print('H'); // soft serial print
  char read_char = mySerial.read();// pushing into variable after soft reading
  delay(1000); // wait for 1 second
  if(read_char == 'H') // if soft serial read byte = H
     Serial.println("Soft Serial is Working"); // hard serail prints
Hackscribble
Try changing this
Code: [Select]
to this
Code: [Select]
SoftwareSerial mySerial(6, 7);
sreenivas
Try changing this
Code: [Select]
to this
Code: [Select]
Thanks for the support, But its not working.
tried
Trial 3
shorted D10, D11
Trial 4
Shorted D6,D7
output is same as previous : -1A-1A-1A-1A .....
Hackscribble
Hi sreenivas
I should have realised this sooner, but you cannot send and receive simultaneously with SoftwareSerial.  So your loop test will miss the data sent.
There is information on this page:
https://code.google.com/p/arduino/issues/detail?id=1111
As PaulS asked, how do you want to use SoftwareSerial in practice?  What is the Nano talking to?  I assume the loop test was just to try out SoftwareSerial?
Regards
Ray
sreenivas
Hi sreenivas
Regards
Ray
Thanks friends for your support....
I  planned to use hard serial for for machine (which has UART) & soft serial for printer.
Hackscribble
Quote
That should be one direction only (assuming no flow control characters back from the printer)?  In which case, should work OK.
