Topic: on/off switches in resistor voltage divider (Read 12536 times) previous topic - next topic
fungus
Yes, a great idea.
Digital ---> analog ---> digital ;)
The idea is that the path is narrower in the middle....
Advanced Arduino
fungus
#16
Jun 18, 2014, 08:45 am Last Edit: Jun 18, 2014, 08:53 am by fungus Reason: 1
If I am using each pins; that would be need maybe 400 pins,
I need double values.
This is unlikely to work.
It might sound good in theory, but ...
Why don't you tell us what you're trying to make/achieve, not what you're doing. That way nobody will waste any time giving non-applicable answers.
Advanced Arduino
Grumpy_Mike
Quote
That implies you need a 20 by 20 matrix of switches.
fungus
#18
Jun 18, 2014, 11:12 am Last Edit: Jun 18, 2014, 11:17 am by fungus Reason: 1
Quote
I spotted that, too!
Sounds to me like somebody's trying to make a MIDI controller (or something similar).
Advanced Arduino
vffgaston
Qwseyvnd
#20
Jun 19, 2014, 04:56 pm Last Edit: Jun 19, 2014, 05:12 pm by Qwseyvnd Reason: 1
See this image:
http://www.airliners.net/photo/Aeroflot/Ilyushin-Il-62/1084219/L/&sid=88b5aa0092f257b39b8336e8d937c49c
Is that possible: Detect which switch toggle switch are used in one pin?
It is possible through this guide:
http://arduino.cc/en/Tutorial/TwoSwitchesOnePin
So, therefore, I wonder if it is possible with three and more switches ?
Grumpy_Mike
See this image:
No way on God's Earth is it possible to read all those switches with one pin.
Two pins an a bunch of shift registers yes but one pin no.
Qwseyvnd
See this image:
You said no? See here: http://arduino.cc/en/Tutorial/TwoSwitchesOnePin
It's possible. So, I wondering if it is possible with three and more.
Grumpy_Mike
If you understood how that technique worked you would know you can not do it with more than two switches. Certainly not 400.
fungus
You still haven't told us what you're trying to do.
I know how to read hundreds of switches using only two Arduino pins but I'm not going to waste time explaining the method unless I'm sure it works the way you need.
Advanced Arduino
vffgaston
Quote
There is a (very old) method (in fact is a primitive DAC) to "read" many switches in an analog input. May be this is what this man (this pollo; I would say) is looking for.
(I adjoint a page of my -very old- Millman)
Grumpy_Mike
Quote
You can't read more switches than you have bits in the A/D converter, possibly two less, with multiple switch contacts!
This guy wants to read 400 switches!
vffgaston
Quote
Absolutelly. I just tried lo give some ligth on the subject.
Regards.
fungus
Quote
Probably a lot less than that in practice, the bottom two (or three) bits of your measurement will be noise, the resistors will have tolerances which will take off another 2 or 3 bits, plus you won't be able to get the exact resistor values you want to make a perfectly linear array (they don't make them in binary values).
etc., etc.
Anyway, the OP seems to have disappeared.
Advanced Arduino
