Topic: Can i use bigger voltage on micro servo?? (Read 3283 times) previous topic - next topic
Smug
I have a Tower Pro SG90 Micro Servo, it says that with 5V the torque is 1,5kg/cm, if i put more voltage, will my servo have higher torque?   Can i use a independet 9V 1A supply without burning it or the arduino board?
CrossRoads
The servo just gets a control signal from the Arduino.
If you exceed the specs of  the servo, you just burn it up.
They are geared device with built in electronics. Not like a DC motor where you can put in higher pulsed voltage to get more out of it.
retrolefty
Most hobby servos are rated for 4.8 to 6.0 vdc, and you will get a little more torque and speed running at 6vdc. Going over 6.0 will only endanger the servo.
MarkT
Some are rated upto 7.2V, it pays to check the actual manufacturer's data...
zoomkat
Quote
Can i use a independent 9V 1A supply without burning it or the arduino board?
You need to run the 9v thru a voltage regulator to keep the servo supply at ~6v. You can use a 7805 regulator chip with a diode like below to supply the servo with ~5.7v. Bottom is a way to wire a servo for external power.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
