While upgrading could improve the situation, the unavailability of the SD card may be an issue with the SD card itself (too new or too old) or with the yun itself. Write to support@arduino.cc if your attempts fail
this is the response in support, and is exactly the problem!!!
The issue could be related to the micro SD card socket. The switch made by two metal springs that closes when you insert the SD card is maybe not closing the contact, so the linux system is not notified by the presence of the SD card. Can you try to push on the metal springs with a small screwdriver, that should allow the card to be detected ?
I have been having trouble with my Yun SD card from the get-go. Putty could see it, but the Yun system could not write to it. After searching for days I ran across this post today and it solved my problem.
quote]
Can you try to push on the metal springs with a small screwdriver, that should allow the card to be detected ?[/quote]
There appear to be a total of 3 springs in my Yun card slot. I used a high power magnifying loupe and a very small flat screwdriver from an eyeglass toolcase to push the metal tab closest to the side even closer to the side. After reinserting the micro SD card and running Putty just to be sure I could identify the card, I ran the Yun datalogger program for a few minutes. I was able to go back in and see that the file had actually been written. Then I tried again, but renamed the file first before uploading the code, and it worked as well.
I am still disappointed that the burden to fix this problem was laid at the feet of the end user. That is what "Quality Control" is for in a a company. We want products that work out of the box. The SD card slot on the Arduino SD card shield seems to be a much better piece of equipment. It uses a totally different card slot.
Thanks all for the perseverence shown to address this big problem, and the many good attempts through software trials first.
houdinihar
