Topic: DHT humidity / temperature simulator 0.1.01 (DHT22 and compatible) (Read 2308 times) previous topic - next topic
robtillaart
To be able to test my DHT library in an easy way I decided to write a DHT simulator a few weeks ago.
This weekend I found some time to read through the specs and wrote the sketch below
I used two potmeters:
one to simulate humidity 0.0 ... 100.0 %
one to simulate temperature -20.0 ... 184.6 C
You can use this code (small changes) to create a virtual DHT22 sensor based upon any other temperature sensor - analog or digital e.g. LM35, thermocouple, DHT11 + DS18B20 etc.  Even non-temperature sensors - e.g. flex-sensor and a bi-metal; pressure-sensor or volume sensor - and some physics formula's can be used to create virtual temperature sensors.
The code is tested on an UNO and a Duemilanove 16 MHZ   - connect datapin & GND  -  and has run for several hours now without  flaws.
I am especially interested if anyone can confirms it works on a ATTINYxx  (for making virtual DHT22's with e.g analog sensors)
Use the code at your own risk, have fun, and as always remarks and ideas are welcome!
Code: (experimental) [Select]
//    FILE: DHT_simulator.ino
//  AUTHOR: Rob Tillaart
// VERSION: 0.1.01
// PURPOSE: simulator to test DHT lib
//    DATE: 2014-06-14
//     URL:
// Released to the public domain
// TODO
// - robustness
// - timeout loops
const int dataPin = 5;
byte b[5];
  Serial.print("Start ");
  Serial.println(__FILE__);
  pinMode(dataPin, INPUT_PULLUP);
  // T = -200 .. 1800
  analogRead(A2);
  int T = analogRead(A2) * 2 - 200;
  // H = 0 .. 1000
  analogRead(A0);
  int H = analogRead(A0);
  if (H > 1000)
    H = 1000;
  //  Serial.print(H);
  //  Serial.print("\t");
  //  Serial.println(T);
  // WAKE UP SIGNAL DETECTED
  if (digitalRead(dataPin) == LOW)
    uint32_t start = micros();
    // wait until signal goes high
    // todo timeout on blocking loop
    while (digitalRead(dataPin) == LOW)
      if (micros() - start > 1500) return;
    if (micros() - start > 500) // serious request...
      DHTsend(H, T);
      Serial.print(H);
      Serial.print("\t");
      Serial.println(T);
void DHTsend(int H, int T)
  pinMode(dataPin, OUTPUT);
  // SEND ACK
  digitalWrite(dataPin, LOW);
  delayMicroseconds(80);                  // 80 us
  digitalWrite(dataPin, HIGH);
  // PREPARE DATA
  b[0] = H / 256;
  b[1] = H & 255;
  b[2] = 0;
  if (T < 0)
    T = -T;
    b[2] = 0x80;
  b[2] |= T / 256;
  b[3] = T & 255;
  // CRC
  b[4] = b[0] + b[1] + b[2] + b[3];
  // SEND DATA
  for (int i = 0; i < 5; i++)
    DHTsendbyte(b[i]);
  // END OF TRANSMISSION SIGNAL
  delayMicroseconds(50);                  // 50 us
  // DEBUG
  //  for (int i = 0; i < 5; i++)
  //    Serial.print(b[i]);
  //    Serial.print(" ");
  //  Serial.println();
// timing manual tuned
void DHTsendbyte(byte b)
  byte mask = 128;
  for(int i = 0; i < 8; i++)
    delayMicroseconds(45);                // 50 us
    if (b & mask) delayMicroseconds(60);  // 70 us
    else delayMicroseconds(24);           // 26 us
    mask >>= 1;
to be continued.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
