Topic: Free virtual Uno simulation environment (Read 411673 times) previous topic - next topic
Geoff
Nice software, thank you very much.
Is it possible to add our own (simple) models of devices?
In our Robotics Club we use the Ultrasonic Transducer a lot (HC-SR04)
Thanks,
  Geoff...
tkbyd
Back in early May, Damain, newbie, 3 posts, announced that there was a malware problem with the simulator downloads.
I looked into it, made enquiries, waited to see what developments arose.
Of several possible explanations, it seems that maybe an .exe being inside a .zip was giving rise to a false positive. I have read many places that Windows Defender is next to useless. I also haven't looked with great care... which is what you need to do in this wicked world, at the download link cited by Damain.
Today, I went to my own page about the simulator...
https://www.sites.google.com/site/unoardusim/services
Used the "Catch your simulator... Go to..." link there, and a little RTMing... the download may not, today, be EXACTLY what is was when I wrote my page... fetched the zip for version 1.5, and on a Windows 7 (until MS highjacks it, with THEIR malware) did a malware scan of it with Eset's Intnernet Security, which I have been happy with for some time. No issues reported.
Off topic rant- Windows.... I've heard it said that the little red "x" in the upper right corner of the "Do you want to upgrade to Wondows 10"- type windows that are plaguing the planet has been reprogrammed to mean "Yes! Update me!"  (You know the window... the one that doesn't have a "no, go away, don't ask again" button.)
One of my systems took 20 hours to download the massive monstrosity that clutters my soon-to-be-Linux desktop PC, VDU monitor, with all sorts of stuff only appropriate to a internet enabled smartpone with a touchscreen. Bah!
Heyo
I have not been able to download the arduino simulator...
kernash
Very nice software, saved me already a lot of time!
However i ran into a problem.
I like to simulate a program which makes use of the virtual wire library.
When including it, UnoArduSim complains at the first line of the library (#ifndef VirtualWire_h):
"PARSE ERROR: unable to parse line".
I'm running it on linux with wine, may that be an issue? Or am I doing something wrong?
Shields_Arduino
Hi kernash, does this work OK on a real Arduino and/or on the Simulator: http://virtronics.com.au/Simulator-for-Arduino.html
Goshawk78
This is a cool tool, but I am having some trouble using it. I am trying to do a simple test where I read a value from a 0-5V slider and then have it translate to 0-360 degrees output to a servo. So far, it will not read in a value from the slider. The servo will accept the output, but the value is not as it should be. Here is the code which I cobbled together. I would appreciate any help pointing out errors and fixes. Thanks in advance,
#include <Servo.h>
const int srvPin = 9;//servo comtrol pulses
Servo servo1;
int count;
int pwmPin = 10; // output pin supporting PWM
int inPin = 3; // voltage connected to analog pin 3, e.g. a potentiometer
int val = 0; // variable to store the read value
float volt = 0; // variable to hold the voltage read
   count=0;
   pinMode(pwmPin, OUTPUT); // sets the pin as output
   servo1.attach(srvPin);//attach servo1
   count=count+1;
   delay(200);
   val = analogRead(inPin); // read the input pin
   volt =(5.0 * val) / 1023; //translate analog 5-volt slider to output range
   val = 360 * (volt / 255); //prepare variable for servo output (0-360)
   //analogWrite(pwmPin, val); //ignore for now
   servo1.write(val);
Shields_Arduino
Hi, this sketch looks OK except for one line:
should be
val = 360 * (volt / 5.0); //prepare variable for servo output (0-360)
In Simulator for Arduino, the output pin changes a shade of red and the angle is displated to the right of the pin.
jqavins
HALP MEH!!!!!!!!!!!!!!!!!!111
No can do, good buddy. Please post
  • The full error message;
  • The full line of code that generates the error;
  • At least one line before, two or three might be better, and one line after wouldn't hurt; and
  • Declarations for all variables used in the code that generates the error.
I'll have a look for what it's worth, and you might get better minds than mine looking as well once there is something to look at.
--  Joe
                Hate is the only enemy.
sirilnasa
Can we interface virtual LED display in Arduino simulator,,..if so can any one tell how,,..?
ubin10
Hello..
perhaps a silly question, is this a standalone simulator ? or do i need to install/run it on the same machine which has Arduino IDE installed ?
Regards
jaivuetasoeur
Woo, this simulator is great, exactly what I what looking for. Thank you mate!
johnfarrugia
I am getting an error when trying to define :
long unsigned int rxID;
"PARSE ERROR: 'unsigned': illegal identifier: matches a reserved keyword in Arduino"
any idea?
ralfiii
Nice tool. Is there a reason it doesn't understand the datatype "short" ?
rcamp48
I really enjoy your simulator, when I can , can I donate towards it ???? I think this is a worthy cause and I usually don't donate to too much to projects unless they are good... but this one is. The only thing I would like to see is  more projects for it. I am part of the Robot Club at KwartzLab in Kitchener, Ontario, Canada (some of you reading this might know me).... if anyone wants more info about the Robot Club or KwartzLab email me back. Thanks... Russ Campbell
Russ Campbell
rcamp48@rogers.com
An Edison Machine In Every Home (from Thomas Edison)
