Topic: Free virtual Uno simulation environment (Read 418383 times) previous topic - next topic
jrf3703
Hello,
I've come across a possible bug.
In the code below, in block //4 the replace seems not to function.
John
   Sample Program to show some string functionsn
//#include "string.h";
   String my_str = "This is my string.";
   // (1) print the string
   Serial.println(my_str);
   // (2) change the string to upper-case
   my_str.toUpperCase();
   // (3) overwrite the string
   my_str = "My new string.";
   // (4) replace a word in the string
   my_str.replace("string", "Arduino sketch");
   // (5) get the length of the string
   Serial.print("String length is: ");
   Serial.println(my_str.length());}
FarooqGul
My code is working perfectly on Arduino uno v3. Simulator is giving error on  #include <String.h>
Error is :
PARSE ERROR: A < > Bracketed #include file name must contain the full drive path
How to solve this issue?
raj556
Thanks for this monumental effort ! I ran the "blink" program and another a string functions testing program and they ran perfectly . I attached a few 'small devices" as well like LEDs and a terminal , was impressed with its functioning. The compiler within it is very friendly and its messages are detailed to solve any coding mistake easily, even compared to the Arduino IDE C compiler. My congratulations. Is there a way to run a HEX file directly in case i don't have C source program ? its needed in some situations where i compile on a different compiler and want to test the hex file on your simulator or someone gives me a hex file to use.
Stanleyarduino
how can I download a Uno simulator in my computer?
please help
pusky
Hi, have not tried this yet, my home system run Ubuntu and centos Linux any thought of porting it?
I will create a windows VM to try it, but would prefer a native version.. please
Or maybe an android one for my old A500 tablet..
It runs both Lubuntu 14.04 and android 5.1.1.
Cheers
Pasquale
noweare
At    https://www.sites.google.com/site/unoardusim/services  the page for the simulator is said.
"This is a simulator for Windows (XP or later). Porting to other operating systems is a project for future."
so it only runs on windows. [ from one 60yr old to another : )  ]
Sandro_Mesquita
Boa tarde, alguém sabe informar onde encontro um curso de Arduino autorizado? Gostaria de certificar professores e a escola pelo Arduino.
Krantz
Hello!
Excellent initiative!
Do you have plans to release it for OSX?
david354
Brilliant.  I am currently developing a flight simulator interface while on holiday without my Ardiuino hardware.  Now I can continue working and testing.
Thank you.
AfricanLionHeart
Waynergy001
Fantastic!
I feel that this is exactly the initiative that Arduino embodies, and encourages, and rightly so.
Are there any plans to develop it into Android and/or iOS?
Docara
Hi Stan,
Constructive criticism - I have just tried your software and it shows fantastic potential! May I make a couple of suggestions for improvement.
1) I would be great if the left hand site 'Coding Window'  allowed us to actual code. This would be beneficial as we would have immediate (instead of - compiled, saving, loading into unoardusim and repeat) feedback for our (newbies) code.
2) The ability to import a Hex file to be simulated.
3) The inclusion of some more hardware eg 1602 displays, 4x 7segment displays, resistive sensors (temp), optical encoders
Thanks again
microsolution
The list of the Top 10 Best Simulators for Arduino is shown in the following.
Paul Ware's Arduino simulator.
Simduino.
ArduinoSim
Arduino Simulator for PC.
Emulare Arduino simulator.
Simulator for Arduino.
Autodesk Eagle.
Proteus.
Autodesk Circuits.
Virtronics Simulator for Arduino
zoomx
I used the Stanley Huang version of CodeBlocks that has a simulator integrated so you can change the sketch, compile a see the result.
The other simulator I used require that first I have to compile in Arduino IDE and then import the binary.
Is there a simulator with integrated IDE so I can do the same that I do in CodeBlocks? I mean that I can modify the sketch and have te simulator that run it (after compiling!).
CtrlON
