Topic: problème shield GSM (Read 5953 times) previous topic - next topic
bearcorrupted
bonjours j'ai reçu il y a peu mon shield GSM Arduino avec antenne intégré
j'utilise une nouvelle carte sim (FREE) testé au préalable sur mon téléphone elle fonctionne
j'ai tout d'abord installer la carte sim branché l'arduino au PC puis téléversé le programme d'exemple arduino pour envoyer des SMS. à  savoir celui là
Code: [Select]
SMS sender
This sketch, for the Arduino GSM shield,sends an SMS message
you enter in the serial monitor. Connect your Arduino with the
GSM shield and SIM card, open the serial monitor, and wait for
the "READY" message to appear in the monitor. Next, type a
message to send and press "return". Make sure the serial
monitor is set to send a newline when you press return.
Circuit:
* GSM shield
* SIM card that can send SMS
created 25 Feb 2012
by Tom Igoe
This example is in the public domain.
http://arduino.cc/en/Tutorial/GSMExamplesSendSMS
// Include the GSM library
#include <GSM.h>
#define PINNUMBER "1234"
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.print("Enter a mobile number: ");
  char remoteNum[20];  // telephone number to send sms
  readSerial(remoteNum);
  Serial.println(remoteNum);
  // sms text
  Serial.print("Now, enter SMS content: ");
  char txtMsg[200];
  readSerial(txtMsg);
  Serial.println("SENDING");
  Serial.println("Message:");
  Serial.println(txtMsg);
  // send the message
  sms.beginSMS(remoteNum);
  sms.print(txtMsg);
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");
  Read input serial
int readSerial(char result[])
  int i = 0;
  while(1)
    while (Serial.available() > 0)
      char inChar = Serial.read();
      if (inChar == '\n')
        result[i] = '\0';
        Serial.flush();
        return 0;
      if(inChar!='\r')
        result[i] = inChar;
        i++;
Mais quand j'ouvre le moniteur série
même en attendant un peu toujours rien
après avoir consulter la doc Arduino j'ai bridgé le pont CTRL/D7
j'ai refait le teste toujours rien même à la fenêtre cela ne marche pas
pourriez-vous m'aidez
merci d'avance
skizoh
#1
Jul 03, 2014, 09:25 am Last Edit: Jul 03, 2014, 09:29 am by skizoh Reason: 1
Salut, après un rapide coup d'œil, tu bloque ici :  while(notConnected), tu ne fait ni ce qu'il y a après ce while ni ce qu'il y a quand tu doit rester dedans, donc je pense que tu dois avoir un soucis, je pense que la condition est toujours vrai mais tu ne sort pas de la boucle while, ce qui est bizar c'est que c'est un exemple arduino :s
Mets des traces :
Code: [Select]
  while(notConnected)
   Serial.println("Connected or not that is the question !?");
      Serial.println("Connected");
Comme sa tu sera ce qui ce passe dans ton while ( ou tu reste bloque si tu veux mon avis )
Skizo.
B@tto
Salut,
Visiblement problème avec gsmAccess.begin(PINNUMBER)
Le shield est officiel ?
Blog électronique : battomicro.wordpress.com
Photographie : www.interactive-celebration.fr
Fablab de Montpellier : www.labsud.org
bearcorrupted
Salut, oui c'est la shield officiel
voici le code avec les marqueurs
Code: [Select]
SMS sender
Circuit:
* GSM shield
created 25 Feb 2012
by Tom Igoe
#include <GSM.h>
#define PINNUMBER ""
GSM gsmAccess;
GSM_SMS sms;
 while (!Serial) {
 // connection state
 // Start GSM shield
 Serial.println(1);
 while(notConnected==true)
   Serial.println(2);
     Serial.println(3);
     Serial.println(4);
 // sms text
 char txtMsg[200];
 readSerial(txtMsg);
 // send the message
 sms.print(txtMsg);
 sms.endSMS();
 Read input serial
 int i = 0;
 while(1)
     if (inChar == '\n')
       result[i] = '\0';
       Serial.flush();
       return 0;
     if(inChar!='\r')
       result[i] = inChar;
       i++;
et voici le résultat
skizoh
Bon bas Segfault sur la fonction xD Vérifie que le numéro de pin que tu utilise est autorisé ou alors que tu à bien mis ton shield comme demandé.
B@tto
Oui il n'y a que gsmAccess.begin(PINNUMBER) qui pouvait faire planter.
Va dans le fichier GSM.h et décommente cette ligne :
//#define DEBUG_ON
bearcorrupted
voici mon fichier GSM.h, il n'y a pas la ligne  =(
Code: [Select]
This file is part of the GSM3 communications library for Arduino
-- Multi-transport communications platform
-- Fully asynchronous
-- Includes code for the Arduino-Telefonica GSM/GPRS Shield V1
-- Voice calls
-- SMS
-- TCP/IP connections
-- HTTP basic clients
This library has been developed by Telefónica Digital - PDI -
- Physical Internet Lab, as part as its collaboration with
Arduino and the Open Hardware Community.
September-December 2012
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
The latest version of this library can always be found at
https://github.com/BlueVia/Official-Arduino
#ifndef _GSM3SIMPLIFIERFILE_
#define _GSM3SIMPLIFIERFILE_
// This file simplifies the use of the GSM3 library
// First we include everything.
#include <GSM3CircularBuffer.h>
#include <GSM3MobileCellManagement.h>
#include <GSM3MobileClientService.h>
#include <GSM3MobileNetworkRegistry.h>
#include <GSM3MobileServerService.h>
#include <GSM3ShieldV1AccessProvider.h>
#include <GSM3ShieldV1BandManagement.h>
#include <GSM3ShieldV1ClientProvider.h>
#include <GSM3ShieldV1DataNetworkProvider.h>
#include <GSM3ShieldV1ModemVerification.h>
#include <GSM3ShieldV1PinManagement.h>
#include <GSM3ShieldV1ScanNetworks.h>
#include <GSM3SMSService.h>
#include <GSM3VoiceCallService.h>
#define GSM GSM3ShieldV1AccessProvider
#define GPRS GSM3ShieldV1DataNetworkProvider
#define GSMClient GSM3MobileClientService
#define GSMServer GSM3MobileServerService
#define GSMVoiceCall GSM3VoiceCallService
#define GSM_SMS GSM3SMSService
#define GSMPIN GSM3ShieldV1PinManagement
#define GSMModem GSM3ShieldV1ModemVerification
#define GSMCell GSM3CellManagement
#define GSMBand GSM3ShieldV1BandManagement
#define GSMScanner GSM3ShieldV1ScanNetworks
#endif
pour le code pin je l'ai retiré
B@tto
Essaye avec cette lib : https://github.com/MarcoMartines/GSM-GPRS-GPS-Shield
bearcorrupted
j'ai installer la librairie puis téléversé le programme exemple de la librairie  a savoir
Code: [Select]
#include "SIM900.h"
#include <SoftwareSerial.h>
//If not used, is better to exclude the HTTP library,
//for RAM saving.
//If your sketch reboots itself proprably you have finished,
//your memory available.
//#include "inetGSM.h"
//If you want to use the Arduino functions to manage SMS, uncomment the lines below.
#include "sms.h"
SMSGSM sms;
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to send and receive SMS.
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20];
    //Serial connection.
    Serial.println("GSM Shield testing.");
    //Start configuration of shield with baudrate.
    //For http uses is raccomanded to use 4800 or slower.
    if (gsm.begin(2400)) {
         Serial.println("\nstatus=READY");
         started=true;
    } else Serial.println("\nstatus=IDLE");
    if(started) {
         //Enable this two lines if you want to send an SMS.
         //if (sms.SendSMS("3471234567", "Arduino SMS"))
         //Serial.println("\nSMS sent OK");
    if(started) {
         //Read if there are messages on SIM card and print them.
         if(gsm.readSMS(smsbuffer, 160, n, 20)) {
              Serial.println(n);
              Serial.println(smsbuffer);
et j'obtiens avec le moniteur série
les led "net" et "status" sont éteintes .
bearcorrupted
une idée du problème ?
B@tto
Si je m'en tiens au site Arduino, il faut inverser les pins dans GSM.cpp :
essaye de remplacer :
Code: [Select]
#define _GSM_TXPIN_ 2
#define _GSM_RXPIN_ 3
par
Code: [Select]
#define _GSM_TXPIN_ 3
#define _GSM_RXPIN_ 2
bearcorrupted
cela donne ça
je suppose que c'est plutôt bon signe par contre si je doit utiliser cette librairie pourrait tu m'indiquer un site où son détaillé les différentes fonctions avec leurs utilités
merci beaucoup
B@tto
Pas vraiment il reboot en boucle ... En plus je viens de relire la page officiel du shield, c'est pas clair mais la définition des pins semblait être la bonne, et la lib que je t'ai donnée ne devrait pas l'être en revanche ...
bearcorrupted
autant pour moi je n'ai pas appuyer sur le bouton "power" après l'avoir fait cela donne ça
j'ai tenté d'envoyer un SMS au shield  au moment ou il marque ATT: OK
B@tto
Avec ou sans inversion de pin ?
