Topic: Powering Servos (Read 4074 times) previous topic - next topic
DannyJeffrey
Hello all.
I am about to build my first robot and I have 3 servos on it (two for wheels, one for moving an ultrasonic sensor, all 4.8-6v). I was wondering if one 4xAA battery (rechargeable pack) would be enough? Or do I need a second powering source for the Arduino mega board?
Sorry if this is a stupid question, it's stumped me.
Thanks!
Pota_Mota
hello
Normally Servos does not need an extra battery pack because they can worck with the electricity that is provided by the arduino.
but, about wat kind of servos do you are talking?
vffgaston
Quote
What . . . .? :smiley-eek:
TomGeorge
Hi, if you are running off battery power, then you will need a separate set of batteries for the servos, they can draw a significant amount of current.
Because the batteries are not a regulated supply their output voltage will vary with the current load, this can and will cause problems with the arduino if they are on the same power pack.
Tom...... :)
Everything runs on smoke, let the smoke out, it stops running....
JimboZA
hello
That comment needs a karma- button.
It's unfortunate that some tutorials say you should / could / can power a servo off the Arduino's 5V, but it's nonsense. You should allow 1A each: worst case is they all stall together so you should be able to supply 3A
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
TomGeorge
Hi, yes, I have run one of the tiny el-cheapo servos off the arduino,but put  them under load and its a different kettle of fish.
Tom.... :)
zaxarias
Really are you gonna use servo motors for wheels ?
z.p
JimboZA
If they're continuous rotation servos, it makes sense. Easier to control that DC: no h-bridge required for example, and one control wire per servo instead of 2 or often 3.
zaxarias
First time i see a project where servos will be used on wheels..
z.p
JimboZA
It's not common.
Real question is, is a servo still a servo when it's a continuous rotation servo?
zaxarias
It's not common.
Maybe it is a servo dreaming of being a DC motor  8) 8) :smiley-mr-green: :smiley-mr-green: :smiley-mr-green:
z.p
zoomkat
Quote
Continuous rotation servos are commonly used in basic small robots.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
