Topic: artificial intelligence robot. (Read 8990 times) previous topic - next topic
zakirox
Hi every one;
this seems to be a silly question. but any way i would like yo ask you all. what is an artificial intelligence robot?  my friends say that it is a robot which will act according to human interaction, with the knowledge of self programming :smiley-eek-blue: . now i am making an my first simple obstacle avoiding robot will it be an artificial intelligence robot  XD ? if not could you please explain me explain me a bit more about this artificial intelligence robot  :smiley-red:
thank you in advance  :smiley-sad-blue: don't think me as a fool
steinie44
Artificial intelligence robot can operate without human interaction.
Using sensors to avoid obstructions and perform or reach a goal.
A RC car is not a artificial intelligence robot, as it needs a human to operate it.
zakirox
i am not going to make it rc control, its an obstacle avoidance robot with using ultra sonic sensors. so will it be an artificial intelligence robot?  :smiley-mr-green: sound like bad i think  :smiley-yell:
steinie44
#3
Jul 04, 2014, 11:26 pm Last Edit: Jul 05, 2014, 12:55 am by steinie44 Reason: 1
Yes and No, I would call it a hybrid.
[EDIT]
Sorry I misread your post. Yes, It will be a artificial intelligence robot.
zakirox
=( i am bit confused with this. i want's to do some more research on this topic. if you would like to help me post some links if possible. thank you
keeper63
Well - let's look at a couple of definitions, shall we?
http://en.wikipedia.org/wiki/Artificial_intelligence
"Artificial intelligence (AI) is the intelligence exhibited by machines or software."
"John McCarthy, who coined the term in 1955, defines it as 'the science and engineering of making intelligent machines'..."
"The central problems (or goals) of AI research include reasoning, knowledge, planning, learning, natural language processing (communication), perception and the ability to move and manipulate objects."
Ok - so basically, for a system to exhibit "artificial intelligence", it needs to be a system which exhibits "intelligence", through the application of "reasoning, knowledge, planning, learning, natural language processing (communication), perception and the ability to move and manipulate objects" - that's the basics. If you system does not do that, it cannot be said to embody "artificial intelligence".
http://en.wikipedia.org/wiki/Robot
"A robot is a mechanical...agent, usually an electro-mechanical machine that is guided by a computer program or electronic circuitry."
So a robot is a machine, guided by a computer (generally, but not always) running a stored program that controls and guides it.
So - what would be an "artificial intelligence robot"? Well, I would say (mashing up these definitions):
"...is an electro-mechanical agent, guided by a computer program and/or electronic circuitry which exhibits intelligence via the application of reasoning, knowledge, planning, learning, natural language processing (communication), perception and the ability to move and manipulate objects..."
Well - not "according to human interaction", but rather "separate or without human interaction" (maybe something got lost in translation, though); in other words, such a robot does not depend upon human interaction (with the exception of turning it on) to be able to navigate, explore, map, understand, interact with, etc - it's environment. In other words, it is an intelligent agent that exists and is aware of it's environment; it doesn't need direction or control from a human to make decisions about how to navigate or otherwise understand that environment. The program which controls the robot keeps track of what it has seen in the past, how it has handled past problems, and/or what the best methods were to solve such problems (such as an obstacle in its way, for instance).
To that end, such a program controlling the robot is "self programming" - it is constantly updating it's understanding of the environment based on the continuous monitoring of sensors versus what it's commands to it's "effectors" were. For instance, if it commands it's arm to move near an object to grab it, it needs to know whether it was successful at grabbing the object, and if not, why - so that next time it tries it will have more knowledge about the situation to try something slightly different (and hopefully be more successful).
now i am making an my first simple obstacle avoiding robot will it be an artificial intelligence robot?
If it just has a simple loop that says "if I sense the object over here, turn in the opposite direction"; then no - that isn't "artificial intelligence".
If instead, you had sensors to detect collisions, and you wrote the code to say "I sense an object in front of me, make a random decision to turn n-degrees in a random amount and continue to drive forward - did I make it? If yes, add that value (plus others - speed, distance to object, etc) to an array, plus a 'success factor' - a number between 0 and 10; the higher the number, the better the success. If not, add that to the array, plus the factor. Next time, look at the array, try something with a high score that matches something close to what you are sensing this time - if it works, increase the value of the factor, if it doesn't, decrease it. If you can't find a match, try another "random" direction selection".
Ok - now that is a lot more complex (and I have probably left some stuff out - but I hope you understand what I am getting at with it) - basically, the system knows nothing about its environment, but over time, by trying random combinations (only after consulting it's "memory" of past successful moves that matched within a certain percentage of the "current" sensing) - it builds up a knowledge base of what and how it most successfully avoided an obstacle.
Something really similar could be done to build up a "map" of the environment the robot is in (this is really complex, by the way - it goes by the acronym of "SLAM" - Simultaneous Localization And Mapping); don't think about trying to implement something like SLAM on an Arduino Uno - while you could implement something extremely simplified, it might also be an exercise in frustration. A better platform for such experimentation (if you wanted to stick with an Arduino, that is) would probably be a Mega2560 with a SRAM expansion board.
I hope the above helps you understand the difference between a robot that is simply programmed by its builder, and one that - while it has a program - is capable of learning about its environment by trial and error, building up a knowledge representation map of these interactions. From there, things can get complicated very quickly.
JimboZA
#6
Jul 05, 2014, 09:09 am Last Edit: Jul 05, 2014, 09:11 am by JimboZA Reason: 1
If instead.... you wrote the code to say <sense stuff, make "random" decisions, store the result and try the best results next time>.
So what's artificial about that? It's no more artificial than the first part.  It's code that instructs the robot to do what you think it ought to do. Why a score between 0 and 10?- that's your intelligence, not the robot's. The notion of comparing things and choosing better ones is merely your intelligence, in code.
Even if a robot....
.... that's your intelligence, not the robot's.
I'm not sure there's any such thing as "artificial" intelligence.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
vffgaston
Hi all,
cr0sh post is, in my opinion, a master one. ¡Congratulations! (Yes, whith the two exclamation simbols; it deserves them).
Just to explore other way: mathematicians say that a machine has AI if you can chat with it an you don't notice it's not human (HAL?. Of course, the term robot is used here in a more general way).
Regards
JimboZA
What cr0sh puts forward is an expert system: it relies on an algorithm based on how an expert would handle the circumstances. The algorithm is turned into code, and then the device behaves as the expert would have.
steinie44
And so is artificial intelligence robot used here in a more general way.
zakirox
hi cr0sh ;
then if a loop that says "if I sense the object over here, turn left and turn right" then find the best direction where to turn. So what you thing about this ?  will it be an intelligent
JimboZA
It's expert, because you had to code into it how to "solve" the problem, based on your expert opinion.
steinie44
Quote from: zakirox on Today at 08:04:04 am
Are we talking 'artificial intelligence' or 'intelligence'?
There is a big difference.
zakirox
hi JimboZA;
i am preparing my coding now onward. i just ordered a robot chassis on ebay and i am waiting till it arrive  ;). here is a piece of my code below.
//If object detected < 5 cm, check for new course
       if (distance < 5){
            digitalWrite(redLed, HIGH);
            digitalWrite(greenLed, LOW);
            tone(speaker, 1000);  //Speaker on
            //First Stop the robot:
            digitalWrite(motorPin1, LOW);digitalWrite(motorPin2, LOW);
            digitalWrite(motorPin3, LOW);digitalWrite(motorPin4, LOW);
            //Now, check space for obstacles:
            for(pos = 10; pos < 170; pos += 1){  // goes from 10 degrees to 170 degrees
                myservo.write(pos);              // tell servo to go to position in variable 'pos'
                delay(10);                       // waits 10ms for the servo to reach the position
            checkLeft = sensor.Ranging(CM);
            for(pos = 170; pos>=11; pos-=1){     // goes from 170 degrees to 10 degrees
            checkRight= sensor.Ranging(CM);
            myservo.write(90);                   // Sensor "look" forward
            //Finally, take the right decision, turn left or right?
            if (checkLeft < checkRight){
               digitalWrite(motorPin1, LOW) ;digitalWrite(motorPin2, HIGH);
               digitalWrite(motorPin3, HIGH);digitalWrite(motorPin4, LOW);
               delay(1200); // delay, change value if necessary to make robot turn.
            else if (checkLeft > checkRight){
               digitalWrite(motorPin1, HIGH);digitalWrite(motorPin2, LOW);
               digitalWrite(motorPin3, LOW) ;digitalWrite(motorPin4, HIGH);
       //No object detected? Ok... all crear to move forward!
       else {
        digitalWrite(motorPin1, HIGH); digitalWrite(motorPin2, LOW);
            digitalWrite(motorPin3, HIGH); digitalWrite(motorPin4, LOW);
            digitalWrite(redLed, LOW);
            digitalWrite(greenLed, HIGH);
            noTone(speaker); //Speaker off
           delay(50); //small delay to read a new distance value from sensor
dear steinie44;
i am sorry, i am talking about artificial intelligence
keeper63
No - I am not postulating on an "expert system":
http://en.wikipedia.org/wiki/Expert_system
"In artificial intelligence, an expert system is a computer system that emulates the decision-making ability of a human expert. Expert systems are designed to solve complex problems by reasoning about knowledge, represented primarily as if-then rules rather than through conventional procedural code."
Those "if-then" rules are also typically represented in a "fuzzy logic" manner; the output of an expert system is typically given in percentages - that is, when the solution of the expert system is arrived at, via the user answering a series of questions presented by the expert system - the solution will be something like "...with 97.32 percent certainty" - or similar output.
What I was proposing was more akin to a machine learning algorithm - and I was trying to simplify the explanation of the process in such a manner without having to get into some of the more esoteric areas of artificial intelligence research - which I admit that I am not an expert on myself - but I have studied the topic at a hobbyist level, and I also took the following courses and passed them (both were very fun and informative):
https://www.coursera.org/course/ml
https://www.udacity.com/course/cs373
BTW - here's an example of self-learning robotic car (namely a neural network) that came out of the ML course (which I originally took when it was presented by Stanford in the Fall of 2011 - the Coursera version of the class came later, but it's the same course):
http://blog.davidsingleton.org/nnrccar/
Anyhow - my point is that what I was trying to describe was an algorithm that attempts to learn which direction to turn best, based on input parameters. Those parameters could be numerous, but imagine a system where the robot "scans" (with an ultrasonic sensor) the area in front of it. It could potentially have multiple obstacles in front of it, at different locations and distances. Now - when it scans, it could build up a "knowledge map" of where things were and how far away they were, then use that information to try to look up in its past knowledge map of what it did in the past, and how successful it was. If it finds something in that map, it could try it out. If it works - then great, update the map to say that it worked again, with a greater probability (my number was "0-10" - 0 being least likely, 10 being most likely; you could easily use a number between 0 and 1 if you would rather work with floating point values, but I was again simplifying things). If it doesn't, lower the probability, then try something else (either re-select out of the knowledge map, or try a random choice of direction, and update the map with that new choice and it's outcome for future tries).
BTW - I am using "knowledge map" here meaning something akin to an array list - not any actual "map" or anything, just to be a bit more clear.
You should be able to see that there isn't any explicit "if this, then turn this way, else turn that way" logic. At first (because the knowledge map is empty) - it's a random choice based on the inputs (what the robot senses); then as the knowledge map is built up, and there exist potential matches (notice I say "potential" - all of this stuff is based on probability matches - not -exact- matches) - those may be tried instead, and depending on how things work out (ie - does the robot get unstuck or does it collide with the object it was trying to avoid?) - the knowledge map is updated (ie - the probability scores for the selected action), etc.
I can't really make it any more clear, only to say it isn't an expert system, it's not a set of rules, and that the program in the computer (controller, mcu, etc) updates it's internal set of states (ie - it's knowledge map of what to potentially try and do based on it's sensor readings) in a continuous fashion as it explores the world. Initially that "map" is empty, but over time it builds it up - hopefully improving as it goes along.
