Topic: How to control LEDs wireless over 433 MHz (Read 6950 times) previous topic - next topic
Experimentaltechnik
Hello,
I`ve made a short video about how to control LEDs with push-buttons wireless with a cheap 433MHz module and the virtual wire library.
I got a lot of information from this great forum, so hopefully sharing this here is helpful for some of you too.
https://www.youtube.com/watch?v=r41txOj71fs
Here are the codes for the transmitter and the receiver:
transmitter:
Code: [Select]
This code changes the state of two variables by pressing two pushbuttons and sends
the information wireless over 433MHz, allowing to remote control two LEDs.
Use the "receiver_LED" code for the receiver.
Made by Matthias - https://www.youtube.com/user/Experimentaltechnik
25.6.2014
#include <VirtualWire.h>
//download the library here: http://www.airspayce.com/mikem/arduino/VirtualWire/
//author of the library: Mike McCauley
byte ledState = B00;
byte ledState2 = B00;
byte ledStates = B00;
byte sendState =0;
int counter =0;
int counter2 =0;
const int buttonPin = 2;    // the number of the pushbutton pin
const int buttonPin2 = 3;
int buttonState;             // the current reading from the input pin
long lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
int buttonState2;             // the current reading from the input pin
long lastDebounceTime2 = 0;  // the last time the output pin was toggled
long debounceDelay2 = 50;    // the debounce time; increase if the output flickers
char ledStatesChar[2];    //char array; stores the Led States; needed in vw_send function
    // Initialise the IO and ISR
    // vw_set_ptt_inverted(true); // Required for DR3100
    vw_setup(2000); // Bits per sec
      pinMode(buttonPin, INPUT);
      pinMode(buttonPin2, INPUT);
  if(sendState == 1){    //data is only send if a button was pressed
    ledStates =(ledState | ledState2);
    itoa(ledStates, ledStatesChar, 10);
    digitalWrite(13, true); // Flash a light to show transmitting
    vw_send((uint8_t *)ledStatesChar, strlen(ledStatesChar));
    vw_wait_tx(); // Wait until the whole message is gone
    digitalWrite(13, false);
  sendState =0;
  //debounce code button 1:
  int buttonValue = digitalRead(buttonPin);
  if ((millis() - lastDebounceTime) > debounceDelay) {
    if (buttonState != buttonValue) {
      if(buttonValue == HIGH){
        counter++;
        if ((counter%2 ==0)) {
          ledState = B00; //00 = first LED off, 01 = first LED on
        else {
          ledState = B01;
        sendState =1;
    lastDebounceTime = millis();
    buttonState = buttonValue;
  //debounce code button 2:
  int buttonValue2 = digitalRead(buttonPin2);
  if ((millis() - lastDebounceTime2) > debounceDelay2) {
    if (buttonState2 != buttonValue2) {
      if(buttonValue2 == HIGH){
        counter2++;
      if ((counter2%2 ==0)) {
        ledState2 = B00;    //00 = second LED off, 10 = second LED on
      else {
        ledState2 = B10;
      sendState =1;
    lastDebounceTime2 = millis();
    buttonState2 = buttonValue2;
receiver:
Code: [Select]
This code receives the LED-states from the "transmitter_LED" code
and turns two LEDs on or off.
25.6.2014
const int ledRed = 2;
const int ledGreen = 3;
    pinMode(ledRed, OUTPUT);
    pinMode(ledGreen, OUTPUT);
    vw_rx_start();       // Start the receiver PLL running
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
        digitalWrite(13, true); // Flash a light to show received good message
for (i = 0; i < buflen; i++)
          ledStatesChar[i] = char(buf[i]);  //save the data
        ledStatesChar[buflen] = '\0';
        ledStates = atoi(ledStatesChar);
    ledState = ledStates & B01;
    ledState2 = ledStates & B10;
    digitalWrite(ledRed, ledState);       //turns the LED on or off
    digitalWrite(ledGreen, ledState2);    //turns the LED on or off
Prit7748
how to change thsi code to keep led on until button is pressed.
if button is not pressed then led should be off.
button pressed led on. button released led off.
beginners123
how about using an hc-12 wireless module?
what's the code?
Almirbajsini
I tried making these but my LED are blinking and when i pres button they stop.
 I dont know how too fix it.
