Topic: Does Arduino have a future? (Read 78272 times) previous topic - next topic
fat16lib
In 2005, Massimo Banzi needed a teaching tool to introduce students to electronics and the result was Arduino.
Now, in 2014, it is not clear where Arduino is going. Here is a quote from  Massimo Banzi.
Quote
We're working on the Arduino Tre, which will be a super small Linux machine, kind of like the Raspberry Pi, that can work with a screen and a keyboard. But even simpler than that, because we want people without a lot of experience in technology to be able to just plug it in and use it. Even if they don't understand Linux yet.
Seems like Arduino is following Pi, BeagleBone, and other companies.  Has Arduino lost its way?
There are now many options for hobby electronics.  These range from Android devices to Field Programmable Gate Arrays.
I ask this question because I don't find new Arduino products very exciting.  I would rather play with BeagleBone Black Rev C than Tre.
There are also totally new areas to explore.  I never expected to see a hobby product like Mojo with FPGAs http://embeddedmicro.com/products/mojo-v3.html.
How do I interpret this mission statement for the future of Arduino?
Quote
Arduino is an open-source electronics prototyping platform based on flexible, easy-to-use hardware and software. It's intended for artists, designers, hobbyists and anyone interested in creating interactive objects or environments.
Arduino is an incredible success but what about the future?
Peter_n
To start with Arduino, a blinking led is very exiting.
The Atmel chips like the ATmega328 are perfect for a simple job, but the cheap ARM chips are hard to ignore.
I think that a basic and cheap chips will be used, and chips with more and other possibilities will be added. So in my opinion, Arduino will be with us for the next 10 or 20 or 30 years.
The FPGA chips are something else, it would need a lot of work to get those into the Arduino IDE.
In the future a FPGA might be build into a microcontroller, to have the best of both worlds.
Riva
It does seem arduino teams goal is to bring new products to market but I feel the support/software for these new devices lags behind. I have had a Duo since it's launch but it has hardly been used. Initially this was because I was not geared up for 3.3V and the documentation/IDE was beta, several months down the line and the IDE is still beta and it seems the takeup/support is not what was (I) hoped. I have since found the Teensy3.1 that seems to be what the Duo could have been.
Maybe we should dust off the old 8051 and it's derivatives and drag them into the 21st century with standardized design/pin outs and IDE.
Don't PM me for help as I will ignore it.
fat16lib
Quote
Doing what?  Like Compaq, DEC, Novell, and many other big high tech companies?  This is just a few of the companies I thought would dominate their market for decades.
Arduino feels like a company that is living on its past success.  I don't plan on buying a Tre, Zero, Intel Galileo, or any other new Arduino board I know about.
Jantje
I feel the yun is really worth looking at. Though a yun mega or a yun teensy3.1 would have been a killer
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Chagrin
Atmel's AVR chips are falling behind the ARM chips (Teensy, Maple, etc.). They need to start kicking up the clock speed and memory to stay competitive. That's my only concern.
With respect to the Raspberry Pi, Beaglebone, etc., those are not microcontrollers. There will always be tons of situations where just a simple microcontroller is warranted and AVR chips will always have their place there.
bperrybap
While I agree that micontrollers will have a place for quite some time, I'm not as
sure about the 8 bit AVRs. I find it increasing painful to deal with when there are other
chips out there that are the same price point like the pic32 that have oodles more
of everything on them, are 32 bit, MUCH faster and don't have the all the split memory
progmem issues.
I mean consider this, if you had your choice, and the cost was the same,
would you pick an 8 bit processor that runs at 16 Mhz with 32k flash, 2k ram, and a funky split
address space where C const data doesn't work
or would you pick a 32 bit processor that runs at 50 Mhz, with 128k of flash, 32k ram,
lots more i/o and peripherals including native USB AND C const data works.
The point is that other much better chips than the 8 bit AVRs are now already available
for the same cost - including in DIP packages,
so I believe that people will start to migrate away from the 8 bit AVRs and eventually leave them behind.
I would bet that if the Arduino were starting to day, it would use a PIC32MX250f128B
rather than the Atmega8.
--- bill
DrOldies
I needed more speed for my projects so I've been testing the DUE, Teensy3, and ChipKit UNO32. I agree that the added power over the original Arduino's is an advantage. The fact that they are Adruino "compatible," can use the large number of arduino libraries, and user experience base, gives them an advantage over "non-compatibles." For example, the much smaller user base for ChipKit has made it harder for me to use this board.
The Galileo will need to develop a user base pretty much from scratch. The TRE is somewhere in between. I'm waiting to see how Arduino compatible the TRE user interface is. I have not see a review of the BeagleBone part of the TRE board. If the BeagleBone is $79, how much more will the TRE be? It's like car companies, they make a cheap Volkswagon Beetle, (I'm old enough to know how cheap the first US volkswagon's were) then over time grow it into a Cadillac. More gadgets I don't need, and more complicated for us less experienced to learn and use.  Where does that leave the hobbiest? The  DUE, Teensy3, and ChipKits  are today's Beetle - a bit faster, a bit more complicated, and a bit more expensive - but still affordable.
dannable
I think if it is to have a future then the infamous Uno 'avrdude: stk500_recv(): ' errors need to be addressed. How many new users encounter this issue and don't get a resolution I wonder? And that is probably the last time they spend money on this platform, maybe this hobby.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
Riva
I have never seen this problem myself with a genuine Arduino board & drivers. Some of the new platforms like the ST Nuclio present a flash drive to the connected PC and programming is as simple as dragging the compiled file into the drive.
fat16lib
Quote
I started to use Arduino because I wanted an easy way to work with microcontrollers.
I started using Arduino in 2008 and wrote the Fat16 library for the 168 Arduino with 16 KB flash and 1 KB SRAM.  It was just a toy to play with.
Now I want a microcontroller like Cortex M4 with more power than AVR but not an application processor designed for "hosting a rich OS platform" like the Cortex A series.
I have been developing a new FAT file system using STM32F4 processors.  The difference in capability over AVR is overwhelming.  I tried to love the Arduino Due when it came out but couldn't.
Here are two examples.
The ADC on AVR Arduinos run at a max of about 10 ksps with analogRead.  You can increase the clock speed and get fair, not full 10-bit, accuracy at 40 ksps.  Low end STM32F4 ADCs can do 2.4 msps, about 60 times faster than AVR with 12-bit accuracy and very flexible DMA.  High end STM32F4 chips can run three ADCs interleaved for 7.2 msps.
I am developing a new file system for high end embedded processors.  The STM32F4 has a good, not great, SDIO controller which can run the 4-bit bus at over 48 MHz.  I have achieved sustained read speeds over 20 MB/sec.  I have sustained write speeds of 12 MB/sec but this is a limited by the SD card I am using.  I have ordered a new Samsung Pro card and hope to write at close to 20 MB/sec.
The AVR can never read or write faster than about 500 KB/sec that's about the best you can do with program I/O on the 8 MHz SPI bus.  In addition SD cards don't present their fast commands on the SPI bus, only on the SDIO bus.  This means you will have very long occasional write latencies with SD cards on the SPI bus.
The Arduino system software is not adequate for these new chips. You really need priority based pre-emptive scheduling to take full advantage of the features of these chips.  Most chip manufactures are now providing a free RTOS solution.  ST and Atmel provide FreeRTOS ports, Freescale has MQX, and there are other great systems like ChibiOS.
I really enjoy development with boards like the  STM32F4 Nucleo boards.  ChibiOS can do about 1.2 million context switches per second on the NUCLEO-F411RE.  I am using a Olimex stm32-H407 and it can do a context switch in 400 ns.  The 407 has 196 KB SRAM and 1 MB flash.
JChristensen
I think I noticed this while working on a recent project and wondered why it happened.
Mr_arduino
fat16lib I must say that I have had a similar experience with the stm32f4 discovery board. Today I was messing around with some of my camera modules that I own and was amazed on the ease of use. All I had to do was setup the DCMI and DMA peripheral and then I can easily take pictures without cpu intervention. I also wrote a program that does real time sample synthesis that is impossible on the arduinos based on AVR mcus.
68tjs
To discuss the future of Arduino there should be more transparency about project in development: TRE and Zero.
- What problems remain?
- Date of delivery
- Selling price
- Progress in library. Remaining bugs.
I have some other remarks :
Quote
One built a microcontroler inside an FPGA and not the contrary. It soon exist: Xilink and Altera propose this.
Quote
[Quote from: dannable on July 14, 2014, 08:47:36 am]
Quote
You perhaps, but I yes. I buy an genuine UNO R2 in an official reseller and it was buggy :  Win 7 and Linux don't recognize it.
At the date of purchase the bug was solved since four months but bugged cards has been sold without correction.
I am convinced that there are three markets:
- Simple applications where avr 8 bits is sufficient
- Most powerful applications where ARM is necessary
- This of some beginners who do not know how to use a microcontroller but absolutely want the most powerful and newest model.
For this market you need one card but no more, it is useless.
The market targeted by the TRE is absolutely not this of beginners.
I find that in this headlong rush, Arduino abandons its core market to a semi-professional market.
In this semi-professional market it will face the MBED project (NXP, Freescale, ST, and so on.) .
For your  information signe on MED , you will discover a true professional environment with a free personal git.
They come from the professional market and they can crush Arduino.
To survive Arduino must not leave the market for beginners and avr.
Three members of forum fit respectively  Eclipse, Code Blocks and Xcode   to arduino libraries .
Whoever adapted Xcode leaves Arduino to Energia, tired that arduino team does not answer his questions.
So Mac user who want use Xcode will switch to Energia.
Why there  has no support from the team ?
The work was done, they had only to formalize and integrate the authors in the team.
May be  they do not want anyone in the team to be able to control everything ?
michinyon
I got two stm32f4,   and compared to the arduino,   they are very hard to use.
Once I got the thing to work,  which took about a year [  I was distracted by other things ],   I implemented a lot of the arduino functions on it so I could use the same stuff.
