Topic: [SOLVED] Arduino uno stuck on "uploading" (Read 28347 times) previous topic - next topic
TheTurtleKing
Jul 13, 2014, 06:22 am Last Edit: Jul 14, 2014, 07:50 pm by TheTurtleKing Reason: 1
it keeps saying "uploading"
can i get my code checked?
int time = 30;
void setup(){
 //start serial connection
 //configure pin2 as an input and enable the internal pull-up resistor
 pinMode(0, INPUT_PULLUP);
 pinMode(2, INPUT_PULLUP);
 pinMode(7, OUTPUT);
void loop(){
 //read the pushbutton value into a variable
 int switchVal = digitalRead(2);
 int sensorVal = digitalRead(0);
 //print out the value of the pushbutton
 Serial.println("Sensor" + sensorVal);
 Serial.println("Switch" + switchVal);
 // Keep in mind the pullup means the pushbutton's
 // logic is inverted. It goes HIGH when it's open,
 // and LOW when it's pressed. Turn on pin 13 when the
 // button's pressed, and off when it's not:
 if (sensorVal == HIGH && switchVal == LOW) {
tone(7, 3000, time*4);
delay(time*4);
tone(7, 2800, time*4);
delay(time*4);
 else {
TheTurtleKing
int time = 30;
void setup(){
  pinMode(7, OUTPUT);
void loop(){
delay(time*4);
delay(time*4);
  else {
turns out it even gets stuck loading on the "bare minimum" example. helppp?
TheTurtleKing
tried doing that "DFU" thing, uploaded a new hex (i think)
still wont run. am i reseting the board correctly?
TheTurtleKing
attempted a loop back test,
it just spit out data from my previous upload, and kept spitting out data
what now?
steinie44
Why are you using pin 0?
Pins 0 and 1 are used to upload by the USB cable.
Don't use pins 0 and 1.
TheTurtleKing
Thanks, noted.
problem is still not fixed, however.
spycatcher2k
Marked as solved - please share your solution with us.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
TheTurtleKing
[solved]
not exactly sure how i solved it.
from what i remember doing, i rebooted my computer and uploading the bare-minimum example into the computer.
bare-minimum example (found on arduino's example guides)
Code: [Select]
ltfrockli
I have experienced this recently, the problem came from board setting was set to another board for unknown reason. After choosing a correct board, it could be uploaded.
Cheers,
Rock Li
PeerlessProgrammer
I had this happen to me on an UNO R3. I solved the issue by disabling Bluetooth on my laptop. It was causing a conflict on COM5.
I had ruled out the board, cable, and IDE. Finally noticed in Device Manager that COM5 had entries (one being the Arduino and the other being Bluetooth). This was on Windows 10 Pro.
Hope that helps someone else that might have this issue in the future.
