Topic: problem with serial port (Read 593 times) previous topic - next topic
shivi_php
guys i am new with arduino this is my first day with arduino i use linux ubuntu 14.10 64bit and i connected my arduino with usb when i try to upload blink program it give me error serial port com1 is not found . when i try to open options and serila port option serial port is disabled why ? how i can solve this problem thanks very much
Peter_n
It might be an incompatible Java TXRX module.
You can try to disconnect and restart the Arduino IDE.
Or you can try the new BETA Arduino IDE. If you download the zip file and unpack it somewhere, you only have to set the folder for your projects files. You can try different versions of Arduino that way.
You could also try to reinstall Java, or install a different Java version.
