Topic: Do i need capacitors (Read 9990 times) previous topic - next topic
Paul__B
So we got the battery sorted out, people were concerned you just might be using a "PP4" battery.   :D
OK, so you are not that silly!
If you are not using PWM, a 0.1µF ceramic capacitor soldered directly across the motor terminals.  YOu will notice this as standard in radio controlled toys.  (Serious models use ESC.)
If you are using PWM, you can still do this, but will need to provide an inductor in series with one or each of the motor terminals - I will "bow out" at this point, of explaining how you should calculate the value.
Zapro
Regarding capacitors on motors for noise-dampening, all you need to know is here:
http://www.beam-wiki.org/wiki/Reducing_Motor_Noise
// Per.
zaxarias
Sure i wouldn't use a solid 9V battery !!!  :D :D :D
Thanks everyone for the useful replies !!!
Quote
Only put 5 batteries in the holder, then you will not waste as much power in the voltage regulator on the Arduino, and your batteries will actually last longer!
// Per.
That can be easily done...
Quote
so its better to solder them on the motor,
You need both a 0.1uF ceramic capacitor for high frequencies and a large one for the low frequencies. If the motor runs in both directions you need a non polarised  capacitor, otherwise an electrolitic will do. The larger the better.
Thanks Mike...
i do use PWM, so can you tell me more about the inductor ? :smiley-eek:
it wont work if i use a polarized or electrolytic capacitor as Mike said ?
Up to now i hear about capacitor on motors, no need to add bypass capacitors anywhere else?
LCD,Bluetooth and distance sensor are powered through arduinos 5V, maybe i should add a bypass capacitor on the 5V output ?
Also should i add a bypass capacitor to the power supply of arduino?
Thanks again !!! :D :D :D
z.p
Grumpy_Mike
Quote
You should have a capacitor on each of your three modules, as close to the module as possible.
zaxarias
#19
Jul 20, 2014, 12:40 am Last Edit: Jul 20, 2014, 12:41 am by zaxarias Reason: 1
Quote
Mike really thanks for replying again.. So one capacitor in each module, electrolytic or ceramic and what capacity?
Also Paul said that PWM won't work if i use a capacitor ..why?
Here is a really quick diagram of the wiring, please let me know if i did something wrong to the bypass capacitors..
z.p
Grumpy_Mike
Yes that is the idea, although you. Although you might  get away with not having them on the lower current devices like the LCD.
I am not sure why Paul said that. In general you do not want to make the capacitor that big wired directly across the motor, just a 0.1 uF ceramic. You want the large one across the motor supply not the motor itself. That is the motor and the driver be it simple FET or h- bridge. When you do then you can put an inductor in seriese with the supply and a capacitor the other side. This is known as a pi filter because it resembles the symbol for the maths constant. Google for an example.
There was a question recently about how to claculate it's value and things got rather over heated. Basically every one was right but some were arguing from mistaken premmisis. (that is probbly a spelling joke - a dyslexic on an iPad is not a good combination as the spell corrector is rubbish )
zaxarias
#21
Jul 20, 2014, 02:19 pm Last Edit: Jul 20, 2014, 02:47 pm by zaxarias Reason: 1
So up to now i 've learned that i have to use a 0.1?F ceramic capacitors soldered on the dc motors and an electrolytic capacitor for each of the other modules(but what about their capacity? electrolytic or ceramic :~ :~ :~ :~ :~ :~ :~ :~ :~)..
Also i think i understand now why i will have problems if i use capacitors with PWM, however PWM is essential to my project so i don't really know what to do !!!
I think here says that a RC(resistor capacitor) filter can make the PWM wotk fine, right ? http://provideyourown.com/2011/analogwrite-convert-pwm-to-voltage/
z.p
Grumpy_Mike
Quote
Not sure what you mean? Use 47uF for the large capacitors.
Quote
No. That is not suitable for a motor. It produces a varying DC voltage, that is not the way to drive a motor and have good speed control.
Read about PWM here:-
http://www.thebox.myzen.co.uk/Tutorial/PWM.html
For a motor you must apply it directly to the motor.
Read this on motors:-
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
For the motor Pi filter read this, it is the last schematic on the page:-
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
zaxarias
Quote
Quote
Mike thanks again, your help is so important !!!  :D :D :D
--Each module(Bluetooth,Distance sensor,LCD) as you said should have a 47uf capacitor ,right? Should it be Electrolytic or ceramic? or it doesn't matter?
--I am familiar with the way PWM works, i saw the schematic you told me and i think it doesn't worth trying to add 4 capacitors and an inductor to each of the four DC motors i use... Otherwise, is there anything else i can do ? Really, PWM ,in practice,wont work at all if i just add a ceramic capacitor to each motor?
z.p
Grumpy_Mike
Quote
You have no choice, you can't get 47uF ceramic capacitors.
Quote
Just adding a 0.1uF capacitor across a motor will not make PWM stop working.
zaxarias
Quote
Great !!!
Quote
[/quote]
Nice to hear that.. So where was the problem? ??? :smiley-eek: :smiley-eek: :smiley-eek:
z.p
Grumpy_Mike
Quote
You tell me?
zaxarias
Quote
You tell me?
if i remember right Paul said that PWM wouldn't work if i use a capacitor...
z.p
Grumpy_Mike
That was if you used a big capacitor not a 0.1uF.
zaxarias
OK, so in summary :
..DC motors: ceramic 0.1uF
..Each other module(Bluetooth,LCD,Distance sensor): electrolytic 47uf
..Servo motor: ????
z.p
