Topic: Project 06 - Negative frequency ? (Read 5737 times) previous topic - next topic
bam94
Hi, I began coding on arduino since last week, and today I'm working on project 06 of the starter kit. Everything is working, however I would like to know value of the frequency that the piezo is playing, that's why I put in the code the function serial.print(). However when I'm checking the value in the monitor, sometimes I have neagtive values of frequency. Do you know what does it mean ? Is there a  problem ?
Here is my code
Code: [Select]
//Play Theremin with a Piezo
// Set up the name of the different variable
int sensorValue;
int sensorHigh = 0;
int sensorLow = 1023;
// assign the variable to the different Pin
const int ledPin = 13;
void setup(){
  pinMode(ledPin,OUTPUT);
  digitalWrite(ledPin,HIGH);
  while(millis()<5000){
    sensorValue = analogRead(A0);
    if (sensorValue < sensorLow){
      sensorLow = sensorValue;
    if (sensorValue > sensorHigh){
      sensorHigh = sensorValue;
  digitalWrite(ledPin, LOW);
void loop(){
  sensorValue=analogRead(A0);
  int pitch = map(sensorValue,sensorLow,sensorHigh,50,4000);
  Serial.print("frequency value: ");
  Serial.println(pitch);
  tone(8,pitch,20);
    delay(10);
I put a screenshot of the monitor at the of this post
Thank you ;-)
steinie44
Code: [Select]
How large a number +/- can an int hold?
Use long
bam94
Use long
According to Arduino website, " int" can hold  a range of -32,768 to +32,767, and "long" can hold a range of -2,147,483,648 to +2,147,483,647.
But I solve my problem, it was during the calibration of the sensor, the problem wasn't come from the code, it was me ^^.
Thank you for your answer.
Have a nice day  ;)
steinie44
Grumpy_Mike
Any bit pattern with the most significant bit set will print out as negative.
Look up "two's complement" for exact details.
http://en.wikipedia.org/wiki/Two%27s_complement
RobRothman
Quote
Posted by: steinie44
My bad, was thinking 40,000
If you can hear 40,000 Hz then you're either a dog or the world's only human with supersonic ears. :D
Rob Rothman
steinie44
Quote
If you can hear 40,000 Hz then you're either a dog or the world's only human with supersonic ears. smiley-grin
Rob Rothman
My dog made me do it. Then he made me fess-up. :)
