Topic: formula per semi onda o idee per lampada rgb (Read 341 times) previous topic - next topic
boschi
salve a tutti, sto creando lo sketch per una lampada rgb, al momento ho questo sketch:
Quote
// fade + white button for rgb lamp
int button = 8;
int ledr = 9; // the pin that the LED is attached to
int ledg = 10;
int ledb = 11;
int brightnessr = 10;    // how bright the LED is
int brightnessg = 125;
int brightnessb = 250;
int val = 0; // per il bottone
int old_val = 0;  // for debouncing system
int state = 0;    // for debouncyng system
int fadeAmountr = 1;   // how many points to fade the LED by
int fadeAmountg = 2;
int fadeAmountb = 3;
// the setup routine runs once when you press reset:
void setup()  {
  // declare pin 9 to be an output:
  pinMode(ledr, OUTPUT);
  pinMode(ledg, OUTPUT);
  pinMode(ledb, OUTPUT);
  pinMode(button, INPUT);
void loop()  {
 val = digitalRead(button);  // debouncing system
  if ((val == HIGH) && (old_val == LOW)){
    state = 1 - state;
   old_val = val;
    if (state == 1){          //stop debouncing system
      analogWrite(ledr, 250);
      analogWrite(ledg, 250);
      analogWrite(ledb, 250);
    else{
  analogWrite(ledr, brightnessr);  // set the brightness
  analogWrite(ledg, brightnessg);
  analogWrite(ledb, brightnessb);
  brightnessr = brightnessr + fadeAmountr;  // change the brightness for next time through the loop:
  brightnessg = brightnessg + fadeAmountg;
  brightnessb = brightnessb + fadeAmountb;
  // reverse the direction of the fading at the ends of the fade:
  if (brightnessr <= 10 || brightnessr >= 250)
    fadeAmountr = -fadeAmountr ;
   if (brightnessg <= 10 || brightnessg >= 250)
    fadeAmountg = -fadeAmountg ;
   if (brightnessb <= 10 || brightnessb >= 250)
    fadeAmountb = -fadeAmountb ;
  // wait for 30 milliseconds to see the dimming effect
  delay(30);
tralasciando il casino o le note poco ordinate, stavo pensando che così non otterrò mai (quasi) tutti i colori in modo ciclico, ma anche semplicemente i colori di base non lì otterrò mai. come potrei fare a ottenerli (quasi) tutti  in modo ciclico?
tazzo
Il classico errore che vedo in progetti come questo è proprio nel dimming, l'occhio è come l'orecchio, una variazione lineare della luminosità non viene vista linearmente. Serve un dimming esponenziale per avere l'impresssione di una luminosità crescente in modo lineare.
