Topic: Saving a short wav file to Attiny85 via the sketch/memory? (Read 8136 times) previous topic - next topic
rcpilotp51
I want to make a small box for my wife with a picture of my son saying a phrase- "I love you" at the press of a button.
I've seen online that several people have used a microSD card to access the file. An sd card seems like a waste for one file.
I was wondering if I could save the audio information in the sketch, using "hoffman code?" I don't know what exactly hoffman code is; but from what i understand it compresses info by reassigning bits to integer values.
Anyway, does anyone know of a way i can play the sound via pwm from the sketch. I'm using this programmer https://www.sparkfun.com/products/11801 and the Arduino IDE. I don't know much about hex files or fuses.
Can anyone help?
AWOL
Did you mean Huffman code?
I'm not sure Huffman coding is directly applicable to audio sample files - maybe to signal deltas, but not to the samples themselves.
Grumpy_Mike
Quote
You could but where are you going to expand them to? Not enough SRAM. Not enough processing power.
Quote
Welcome to the real world.
JChristensen
Without compression, even one second of low-fi monaural audio (e.g. 3kHz bandwidth) will require more memory than the ATtiny85 has. Perhaps it could be made to fit with compression, but then as Mike says, there are other significant resource issues.
rcpilotp51
Thanks guys:
http://elm-chan.org/works/sd8p/report.html
can anyone help me with the above? I'm not great at reading schematics (getting better though).
does anyone know of a breadboard fritzing diagram out there that i can play with?
or can anyone explain this a bit better; if i can figure this out...ill use this method...thanks
Keith
JChristensen
Interesting project, at least as an end in itself. Seems I've seem small "toy" voice recorders for a few bucks that will record at least for several seconds.
rcpilotp51
Yeah...i was hoping to expand on the project later (and learn a little bit now)
Keith
JChristensen
rcpilotp51
The schematic above looks fairly simple; can anyone break it down from pin to pin for me ?
rcpilotp51
for instance there are somethings on here that aren't labeled:
http://elm-chan.org/works/sd8p/rc/sd8p_mo.png
Grumpy_Mike
What isn't labeled then?
AWOL
#11
Aug 04, 2014, 08:30 pm Last Edit: Aug 04, 2014, 08:32 pm by AWOL Reason: 1
The two caps?
Edit  oops, battery and cap.
rcpilotp51
The OCL version looks like it only uses the 104 Cap... whats the difference? OCL or low res?
I think the OCL will work for my needs. Thoughts?
where do i find the pinout for the SD card?
rcpilotp51
found this:
https://my.st.com/public/STe2ecommunities/ImageLibrary/SD%20card%20pinout.jpg
Grumpy_Mike
Quote
On the picture you posted?
Quote
That is a 0.1uF ceramic cap for supply decoupling.
Can you guess what the battery voltage is?
