Topic: Saving a short wav file to Attiny85 via the sketch/memory? (Read 8144 times) previous topic - next topic
rcpilotp51
I think I'm going in circles. based on the source code how can i successfully load it on the chip?
Grumpy_Mike
I don't think you can it looks too big.
The hex file is 19K so assuming two bytes per machine code that gives a rough size of 9.5K. It will be less than that because of the headers and check sums so I think you are over the 8K limit for this chip.
You will need a programmer or an arduino programmed up as a programmer to program without a bootloader.
rcpilotp51
others have done it... thats odd.
http://elm-chan.org/works/sd8p/report.html
there are a lot of videos of people who have done it:
https://www.youtube.com/watch?v=RVC_nLZy-T8
hmmm... if i burn the 8mhz boot loader and try to load the .c files would that change anything?
rcpilotp51
rcpilotp51
Grumpy_Mike
Sorry I only play with boot loader systems not with direct stuff.
