Topic: "avrdude: stk500_recv(): programmer is not responding" error (Read 6766 times) previous topic - next topic
Foxworrior
I get the error whenever I try to upload a sketch (just a blinking led sketch) to my Arduino due.
In the ports tab I can't see any usb ports and I have made sure that the correct board is selected, I don't know what else I can try.
johnwasser
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Foxworrior
Thanks johnwasser, that helped however I now receive different error messages.
Code: [Select]
Arduino: 1.5.7 (Mac OS X), Board: "Arduino Duemilanove or Diecimila, ATmega328"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
spycatcher2k
you have the wrong board selected 'Arduino Duemilanove or Diecimila, ATmega328'
Choose Due
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
Foxworrior
Wow, that fixed it.
Thanks both of you for your help!
robnv
This seems to be a mac problem.  I have loaded the sketch using windows and Mac  and not had a problem with Windows.  The minute I go to Mac Os Avrdude. problem.  Amtel and Apple needs to be bitched at!!  They changed how Amtel chips are talked too.  Until this APPLE problem is fixed kiss the Arduino platform goodbye unless you run an earlier driver file.  Apple  Dumb Asses messing with good working driver files and it was not an security issue.  I say lets tar and feather them.  The only time you will get honest politicians or software writers  is when capital punishment is part of the equation.  Apple can you hear me calling.
robnv
spycatcher2k
Mrs Drew
