Topic: SIM900 from seedstudio / no internet conection (Read 2573 times) previous topic - next topic
limace
I have the Shield GPRS from seedstudio:
http://www.seeedstudio.com/depot/GPRS-Shield-V20-p-1379.html
And One Arduino UNO
The simple call, sms run well but I have some problems with the internet conection
Code: [Select]
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial mySerial(7, 8);
  mySerial.begin(19200);               // the GPRS baud rate
  SIM900power();
  if (Serial.available())
    switch(Serial.read())
     case 'h':
       SubmitHttpRequest();
  if (mySerial.available())
    Serial.write(mySerial.read());
void SubmitHttpRequest()
  String humidity = "1031";
  mySerial.println("AT+CSQ");
  delay(100);
  ShowSerialData();
  mySerial.println("AT+CGATT?");
  delay(100);
  ShowSerialData();
  mySerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");
  ShowSerialData();
  mySerial.println("AT+SAPBR=3,1,\"APN\",\"internet\"");
  delay(4000);
  ShowSerialData();
  mySerial.println("AT+SAPBR=1,1");
  delay(2000);
  ShowSerialData();
  mySerial.println("AT+HTTPINIT");
  delay(2000);
  ShowSerialData();
  mySerial.println("AT+HTTPPARA=\"URL\",\"www.xxx.com/ab/tx.php?h=" + humidity + "\"");
  ShowSerialData();
  mySerial.println("AT+HTTPACTION=0");
  delay(10000);
  ShowSerialData();
  mySerial.println("AT+HTTPREAD");
  delay(300);
  ShowSerialData();
  mySerial.println("");
  delay(100);
void ShowSerialData()
  while(mySerial.available()!=0)
void SIM900power()
// software equivalent of pressing the GSM shield "power" button
  digitalWrite(9, HIGH);
  digitalWrite(9, LOW);
  delay(5000);
Reponse:
Code: [Select]
+CSQ: 10,0
OK
AT+CGATT?
+CGATT: 0
OK
AT+SAPBR=3,1,"CONTYPE","GPRS"
OK
AT+SAPBR=3,1,"APN","internet"
OK
AT+SAPBR=1,1
ERROR
AT+HTTPINIT
OK
AT+HTTPPARA="URL","www.XXXX.com/ab/tx.php?h=1031"
OK
AT+HTTPACTION=0
OK
+HTTPACTION:0,601,0
AT+HTTPREAD
OK
I have make a lot of search but no response
Thanks for your help
dannable
Is the APN parameter the real one you use or have you inserted dummy data?
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
limace
#2
Aug 08, 2014, 11:14 am Last Edit: Aug 08, 2014, 11:21 am by limace Reason: 1
I stupidly copied the parameters of code that I found  :smiley-red: . It depends on my access provider I guess? What needs to be changed and how?
In my provider I find this :
APN Internet
Nom : Free
APN : free
MCC : 208
MNC : 15
By typing the code I figured that the error come from this line ...
mySerial.println("AT+SAPBR=3,1,\"APN\",\"free\"");
I'll test now ... :D
dannable
I would expect your parameters to be something like this, depending on your service provider:
Code: [Select]
AT+SAPBR=3,1,"APN","internet.myprovider.com"
AT+SAPBR=3,1,"USER","web"
AT+SAPBR=3,1,"PWD","web"
AT+SAPBR=1,1
limace
I have only put this and it seems to work   :smiley-mr-green:
Code: [Select]
  delay(100);
  ShowSerialData();
  ShowSerialData();
  delay(4000);
  ShowSerialData();
Thanks  a lot
