Cross post, see previous msg again.
If the package is dil and not surface mount the circuit should be correct.
yup, it's a regular DIP package, checked with the datasheet to make sure the pinout matches this diagram (and measured every pin already a dozen of times to be really really REALLY sure that every pin is wired the same).
the only difference i have with the diagram is the resistors. don't have 2K resistors atm, so i tried with 1K and 10K, but googling circuits with this DAC, i find them with just about every imaginable resistor value... so i don't think that'll be the issue either. I've also got 3 of these dacs, so i tried switching it with another one to make sure it's not a defective chip, but the others do exactly the same.
what i'm currently wondering is: most diagrams show this thing being hooked up to systems that provide positive & negative voltages to pins 3 & 13 (like +12v and -12V), since i'm hoping to just use it with an arduino and without an extra power supply, i was glad to find the above diagram that simply uses it with 0 and 5V, but could that be the issue?
