I'll definetly go with the WT588DU-32. Cause i want a lot of sounds.
You use the programmer board, but I'm goin the USB I figure.
So then you would use female pin clips with wires on the module to make the connections?
Just like computer clips ahhhh... damn I'm dense.
Or do the boards come un-soldered and are not pictured that way on Yahoo?
Desoldering that long strip would put a lot of heat onto the board.
The Arduino definitely comes un-soldered.
? For Jakesoft
Also what voltage rating "mosfets do you use on the led's? I know that the red can't run as much
power as the Blue and Green. You say you run at 1amp, but I read they run at like
3 watts Blue and Green, and like 2.3 for the Red. So bust out that resistor calculator thing I suppose if I want to use resistors. I have two 18650's I'm gonna use, for power. So I'm wondering about the levels that I would want on the RGB 3w LED I'm gonna use. I'll read other posts as well on CSS forums. I guess they all use 350 mah, Voltage(Vf): Red:2.0-2.5V Green:3.2-3.6V Blue:3.2-3.86. So again mosfets, buckpucks, and capacitors.
Maybe this?
http://www.ebay.com/itm/Water-Proof-Power-Supply-LED-Driver-for-3x3w-10w-20w-30w-50w-100w-SMD-LED-Light-/321813500544?var=&hash=item4aed945280:m:mn8PQXKV_jQqUiSktcQGv7AAs I hit the next part purchase I'm asking whats perplexin me.
Told ya I'm a noob, If I had to write the above from memory, good luck lol!
Ok time to order parts.
