Topic: Arduino Lightsaber (Read 458451 times) previous topic - next topic
billpealer
Completely right.
I would only add, that most current control circuitry actually varies the voltage to make sure the current is constant. Reason is, it's easy to play with voltage. Usually then there is a shunt resistance to sense the current (convert the current to voltage again), and based on that sensed current (which is a voltage, lol), adjust the voltage to ensure the current is stable.
hook a car battery up to your buckpuck, don't PWM control it or analog potentiometer it,..  plug it into your blue luxeon.  start the timer.
wailer
#646
Feb 05, 2016, 03:33 pm Last Edit: Feb 05, 2016, 04:02 pm by wailer
it will not help you with the ADXL
I know, but i think i can can tackle that problem myself found some other example code that will get me started, should not be too hard.
Will post examples as soon as i got it figured out.
If you wan't to teach people how to fish hand them a fishing rod :).
btw was my i++ explanation any help?
JakeSoft
If we are waiting for the LED to blow up, then we'll be waiting for a really long time. 12 volts is 12 volts, regardless of the source. Because science.
billpealer
#648
Feb 05, 2016, 09:14 pm Last Edit: Feb 05, 2016, 09:45 pm by billpealer
the buckpuck model in question is variable voltage based on the input.  7v in would yield 3.4v 700ma (according to luxdrive)  12v in would be,...  more.  this is from Luxdrives FAQ
"Can I input more voltage than my LEDs need or will that hurt my driver and/or LEDs?
Yes, you can input more voltage than your LED needs as long as it is in the driver range of 5-32VDC. It is best practice to use an input voltage that is closer to your needs. For example if your system ran around 7 volts, it is better to stick with the 12VDC than to use a 24VDC, whereas the 24VDC input would still work, it is better for the system overall if you used the closer value."
do you think the buckpuck can intelligently detect the MAX VF for any 3W LED and alter its voltage? If so,..  where does all the extra V go,?..  it's not being converted to A like most buck/boosts,  that = heat on the puck.   i was not interpreting that as the case from the above Q/A. 7v and 700ma will cook a 3W LED with passive cooling.  7v * 700ma = 4.9 Watt
stop judging me!
DJWing79
ok, here's another question....can I use one buckpuck to drive the constant amperage out at 1000 ma but not use the control pin (not getting a dimmer module) and instead have the Negative out feed through a N-FET gate like my current build...would that work? I haven't done my test yet, but I've heard the buckpucks don't generate heat in the same way a boost module would
Protonerd
:) please read the manual:
"The 3021/3023 Wide Range LED Power Module is a high efficiency dc to dc converter which delivers a fixed output current by varying the output voltage as required to maintain the specified current .  A fast response current-sensing circuit permits the unit to be used in applications where flashing or pulsing of the LEDs is required."
I swear I did not, I simply have tons of experience with such circuits.
Kdot
#651
Feb 08, 2016, 07:57 pm Last Edit: Feb 08, 2016, 08:03 pm by Kdot
So been a minute on posting here, however the progress has not stopped.
I completely have redone my coding, using this for my switch and swing Click here. I was looking for who posted there code for the plasma saber, thanks for that! Did have to add a bit more coding to make the debounce work though.
I have worked out most my audio issues. Start up to Hum is seamless now, and was able to get rid of the 1700ms delay. Working on getting swing to be long enough to hear and switch to Hum seamlessly, only hangup i have now is getting the full swing to play quick enough for another swing, however i think a second sensor might help that. Also have my 3W Cree Blue LED hooked up. Will try and get a video soon.
Sample code:
else {
     PlayComplete(2);
     SABER_On = true;
     Serial.println("Saber is off, turning it on");
     for (int fadeValue = 30 ; fadeValue <= 255; fadeValue += 5) {
       // sets the value (range from 0 to 255):
       analogWrite(LED_test, fadeValue);
       // wait for 30 milliseconds to see the dimming effect
     delay(30);
     PlayLoop(1);
 //Is a swing detected
 if (SW_justpressed[1]) {
   SW_justpressed[1] = 0;
   if (SABER_On) {
     Serial.println("Swing detected");
     Serial.println("Playing swing sound");
     PlayComplete(randNumber = random(3, 7));
     delay(150);
     PlayLoop(1);
purgedsoul
been working on this part, something about using the delay function to wait for the first sound to finish, is doing this. Need to replace this with a non-blocking delay... if anybody can come up with this solution please do share.  :)
DJWing79
have you tried using millis?
Kdot
purgedsoul! thank you so much, i took the sample code you had posted previous and have been reworking that to fit my setup.
@DJWing79, i started to play with that, but was not 100% sure of what i was doing, but was kind of a side thought while working something else out
wailer
#655
Feb 11, 2016, 12:17 am Last Edit: Feb 11, 2016, 12:28 am by wailer
Sample code, wtd533 arduino library and even saber wave files can be found here https://github.com/ACDCLabs/WT588D.git
Even a complete bin file that can be uploaded to the 533 directly is in the repository.
Too bad no accelerometer code, but hey my own code is slowly coming together.
Thanks JakeSoft ahum....just kidding i mean Ecloud thanks for the fish man ;)
stinky1
Here is a link to a lightsaber build that has RGB PWM code in it.  It uses a Joe Jedi or MR616 sound card,  so of course this is not a drop it in and it will work code for the whole shebang,  but will show you code that will need to be adjusted to your build.
Arduino as RGBx PWM controller and Soundcard interface
I was gonna post the code,  but its over 9,000 limit lol!!!
purgedsoul
Welcome Kdot, glad it helped.
JakeSoft
You are welcome for the parts lists, sample code, 100+ support posts, this thread, example videos, and of course the original idea.
wailer
Of course thanks for that, without this thread i would not have come this far.
But sifting through all snippets of sample code is pretty hard work and contributing to a  more or less completed code would be more efficient, and more of a "open source" idea.
But that is my humble opinion.
