Topic: Arduino Lightsaber (Read 469052 times) previous topic - next topic
alangarcia
Nice!  The Force is strong with this one  8)
wildjack6
Just curious what you used for clash and swing sensor
purgedsoul
So this module can actually do gapless play back? Excellent!
privateRob
Awesome²  8)
What speakers did you use? (8ohm 0.5watt?)
How many db did you get? (It seems as loud as a smartphone on full volume)
On your schematic you didn't use any amplifier, right?
Since you nearly answered all component related questions, you should add the whole list to the first post if possible!
JakeSoft
Yes! Two ways to do it, even:
1. There is a "repeat" serial command that you can send. It will repeat whatever sound is played with no gaps. As long as there are no dead spots at the start or end of your sound files then it works great.
2. You can program the WT588d to play a list of up to something like 200 sounds when commanded. Sounds are played back-to-back with no gaps.
wildjack6
Would you be willing to share some of your code for the soundboard I started playing with it but can't figure out how to get it to repeat any suggestions would help
JakeSoft
#22
Oct 09, 2014, 03:29 am Last Edit: Oct 09, 2014, 03:32 am by JakeSoft Reason: 1
Sure. Here is the most important part of the code from SugarBombs:
(See full code here: http://forum.arduino.cc/index.php?topic=227435.0)
void WT588D_Send_Command(unsigned char addr) {
 unsigned char i;
 digitalWrite(WT588D_CS, LOW);
 delay(5); //delay per device specifications
 for( i = 0; i < 8; i++)  {
   digitalWrite(WT588D_SCL, LOW);
   if(bitRead(addr, i))digitalWrite(WT588D_SDA, HIGH);
   else digitalWrite(WT588D_SDA, LOW);
   delay(2);  //delay per device specifications
   digitalWrite(WT588D_SCL, HIGH);
 } //end for
 digitalWrite(WT588D_CS, HIGH);
} //end WT588D_Send_Command
Try putting this somewhere in your code:
//Turn on repeat mode
WT588D_Send_Command(0xF2);
//Begin playlist 0
WT588D_Send_Command(0x00);
Of course, make sure the WT588d is configured for 3 line serial mode.
JakeSoft
#23
Oct 09, 2014, 03:40 am Last Edit: Oct 10, 2014, 11:38 pm by JakeSoft Reason: 1
Awesome²  8)
Thanks!
Right, no amplifier needed (although you could certainly add one if you wanted it louder and could find room for it). I don't have any equipment that would allow me to measure it in db, but it's loud enough for me. Smartphone on full volume is probably a pretty good comparison.
I used this speaker in the finished product (8 ohm, 2W):
http://www.thecustomsabershop.com/2W-28mm-Bass-Speaker-P662.aspx
During my breadboarding, I used a very cheap 8 ohm 0.5W speaker that I harvested from a toy. It worked fine, but the sound quality was pretty terrible. Really you should be able to use any 8 ohm speaker with at least a 0.5W power rating. It all depends on your budget and what kind of sound you're looking for. I'll leave that discussion to the audiophiles.
wildjack6
Thanks for the help I will try it out and see what I can get working totally new to programming so any help is appreciated
JakeSoft
Glad I could help. Just be sure call the WT588D_Send_Command() function from somewhere outside your main loop, like when a button is pressed or something, otherwise you may get odd behavior.
wildjack6
Playing with it hopefully can figure it out lol
privateRob
Thank you!
You Sir earned your first karma for all the questions you answered in this thread!
JakeSoft
Thank you!
Yay!  8)
egoic
You can throw a few pictures of the entire system with speaker and LED??? :D
