Topic: Control robotic arm using arduino and kinect (Read 7860 times) previous topic - next topic
PaulS
Quote
Could you please simplify it ?
I can't see how.
Does the application that is sending data to the Arduino have the capability to receive data from the Arduino and display it to you?
dimis90
Quote
I can't see how.
The application is only sending not receiving. Arduino is only receiving and do some calculations  all i want is to see what arduino is receiving but i can't do it through serial monitor because the port is in use when i am running the code from c# so i am asking you is there another way to see how can i see what arduino is receiving?
PaulS
Quote
Without additional hardware, no.
zoomkat
There is serial port monitoring software available that will run on the pc and capture the transactions occurring on the serial port. In the past i used a program called portmon to monitor serial communications.
https://www.google.com/search?as_q=serial+port+monitor&as_epq=&as_oq=&as_eq=&as_nlo=&as_nhi=&lr=&cr=&as_qdr=all&as_sitesearch=&as_occt=any&safe=images&tbs=&as_filetype=&as_rights=&gws_rd=ssl
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
dimis90
PaulS thank you for your time and zoomkat this program really did the trick thank you too
